TSB 08-25-01 - 6.4L White Smoke
Keith Browning
FORD: 2008-2009 F-Super Duty
ISSUE:
Some 2008-2009 F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine and built before 10/1/2008 may exhibit significant amounts of white smoke from the exhaust pipe while driving in high humidity or rainy conditions at temperatures above 40 °F (4 °C). This smoke only appears during a moderate to full throttle tip-in that is performed after a period of steady state driving.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
This procedure only applies if the vehicle meets the following criteria:
  • Concern is described as significant amounts of white smoke from the exhaust pipe.
  • White smoke only occurs in high humidity or rainy conditions above 40 °F (4 °C).
  • White smoke only appears during a moderate to heavy tip-in that is performed after a period of steady state driving (approximately 20 minutes)
  • No diagnostic trouble codes (DTCs) are present.
  • Concern is not a result of regeneration, a cleaning exhaust filter event.
If all of the criteria above is true, then replace the Charge Air Cooler Assembly with a new revised part per Workshop Manual, Section 303-12.
PART NUMBER PART NAME
7C3Z-6K775-B Charge Air Cooler Assembly
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
082501A 2008-2009 F-Super Duty 6.4L: Replace The Charge Air Cooler, Includes Time To Check For DTCs (Do Not Use With 6775A, 12650D) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
6K775 42
  • 1 month later...
