6006 Service Engine
AMCTech
I've recently completed an engine R&R on a 03 450 ambulance. The engine used was the Ford/Motorcraft 6006 unit. I must say I was impressed with the engine as delivered. It was crated well and delivered 48 hours after the order was placed. All sensitive openings were carefully plugged, although the black paint was put on a little thick. On the first prove-out run, it ran smoothly and well. In fact, it was the best performing early 6.0 I've driven. Some notes: the injector connectors were clocked to the 12 position, like on later builds; the rocker-cover studs were not placed correctly; the thickly applied paint had to be chased from motor-mount and front cover threaded holes, as well as the bell-housing area. Other than that, it is a straightforward affair that worked well.
