2009 Truck & Diesel SSMs
Keith Browning
3023 - 6.0L IPR SCREEN - PART AVAILABILITY
6.0L DIESEL ENGINE EQUIPPED VEHICLES THAT PREVIOUSLY REQUIRED INJECTION CONTROL PRESSURE REGULATOR (IPR) VALVE REPLACEMENT DUE TO DEBRIS OR DAMAGE TO THE IPR SCREEN, CAN NOW BE SERVICED AT A LOWER PART LEVEL. THE IPR SCREEN CAN BE SERVICED WITH PART # 3C3Z-9H529-A AND DOES 'NOT' REQUIRE THE ENTIRE IPR VALVE TO BE REPLACED. REFER TO THE SERVICE PROCEDURES IN THE WORKSHOP MANUAL SECTION 303-04C, IPR VALVE SCREEN REPLACEMENT PROCEDURE FOR ADDITIONAL DETAILS.
3000 - MULTIPLE VEHICLE LINE MAF SENSOR SERVICE TIP.
SOME 1997-2010MY GAS ENGINE EQUIPPED VEHICLES MAY EXHIBIT DIAGNOSTIC TROUBLE CODES P0171-P0175 WITH LACKS POWER, HESITATION, RUNS ROUGH OR SURGE DRIVABILITY CONCERNS DUE TO CONTAMINATED MASS AIRFLOW SENSORS(MAF). IF NORMAL PCED DIAGNOSTICS LEAD TO THE MAF SENSOR, CAREFULLY INSPECT SENSOR HOTWIRE FOR CONTAMINATION. IF HOTWIRE IS CONTAMINATED WITH OIL, DIRT OR DEBRIS CLEAN THE SENSOR WITH CRC MASS AIR FLOW SENSOR CLEANER #05110. DO NOT USE SHOP AIR OR HARSH CHEMICALS SUCH AS BRAKE PARTS CLEANER OR CARBURETOR CLEANER ON MAF SENSORS. THIS CAN CAUSE SERIOUS DAMAGE TO SENSITIVE ELECTRONIC PARTS. CRC MAF SENSOR CLEANER WILL SAFELY AND EASILY CLEAN THE MAF HOTWIRE AND ELECTRICAL COMPONENTS WITHOUT DAMAGE TO THE WIRES OR PLASTIC HOUSING. MONITOR LONGFT1 AND LONGFT2(DUAL BANK ENGINES) PIDS AFTER MAF SENSOR CLEANING TO CONFIRM REPAIR.
2992 - 6.0L EGR VALVE DIAGNOSTICS
ENGINEERING INVESTIGATION COMPLETED ON 6.0L EQUIPPED VEHICLES THAT EXHIBIT EGR RELATED DTC P0401, P0402, P0404, P1335 AND P1408 ALONE OR IN COMBINATION. THE IDS 'EGRVP RESPONSE TEST' (EGRDC VS. EGRVP) HAS BEEN UPDATED TO PROVIDE MORE ACCURATE TEST RESULTS AND THE ASSOCIATED PINPOINT TESTS HAVE ALSO BEEN UPDATED. VERIFY YOUR IDS IS AT RELEASE 64.01 OR HIGHER AND USE THE ON-LINE VERSION OF THE APPROPRIATE PC/ED PINPOINT TESTS TO INSURE ACCURATE TEST RESULTS.
2987 - 2008-2010 F-SUPER DUTY - P20E2, P20E3, P20E4, P2080, P2084, P242B, P0544, P02031, P242A OR P200E SET DUE TO EGT CONNECTION CONCERNS
SOME 2008-2009 SUPER DUTIES WITH A 6.4L DIESEL ENGINES EXHIBITING DIAGNOSTIC TROUBLE CODES P20E2, P20E3, P20E4, P2080, P2084, P242B, P0544, P02031, P242A OR P200E. THIS MAY BE DUE TO INTERMITTENT CONNECTIONS AT EXHAUST GAS TEMPERATURE(EGT)SENSOR CONNECTORS(C3301-03) OR INLINE CONNECTOR C110. ALLOW EXHAUST SYSTEM TO STABILIZE TO THE AMBIENT TEMPERATURE PRIOR TO MONITORING EGT SENSOR PID'S. IF EGT SENSOR PID VALUE IS WITHIN 20C(36F)OF ONE ANOTHER PERFORM A WIGGLE TEST TO IDENTIFY SUSPECT SENSOR. IF EGT SENSOR PID VALUE IS NOT WITHIN 20C(36F) OF OTHER PID VALUES, DISCONNECT SUSPECT SENSOR AND CLEAN THE CONNECTION AND C110 CONNECTOR PINS WITH CONTACT CLEANER. APPLY DIELECTRIC GREASE BEFORE RECONNECTING. CONFIRM REPAIR BY MONITORING EGT PID'S. IF SUSPECT EGT SENSOR IS STILL OUT OF RANGE, FOLLOW NORMAL PC/ED PPT RC DIAGNOSTICS.
2979 - SYNC, MULTIPLE VEHICLE LINE AND MODEL YEAR - SYNC SYSTEM VOICE TOO LOUD, TOO QUIET.
SOME 2008-2010 SYNC EQUIPPED VEHICLES MAY EXHIBIT THE SYNC SYSTEM VOICE TOO LOUD OR TOO SOFT. THIS IS A NORMAL SYSTEM OPERATING STRATEGY AND NO REPAIR IS NECESSARY. THERE WILL BE NO REVISIONS FOR THIS IN THE FUTURE FOR THE 2008-2010 MODEL YEAR VEHICLES. DO NOT REPLACE OR UPGRADE THE ACCESSORY PROTOCOL INTERFACE MODULE(APIM)FOR THIS CONCERN. NOTE: ENGINEERING IS INVESTIGATING THIS CONCERN FOR 2011 SYNC EQUIPPED VEHICLES. MONITOR OASIS FOR FUTURE UPDATES FOR 2011 MODEL YEAR VEHICLES.
2978 - SYNC, MULTIPLE VEHICLE LINE AND MODEL YEAR - SYNC CALL VOLUME TOO LOUD, TOO QUIET.
SOME 2008-2010 SYNC EQUIPPED VEHICLES MAY EXHIBIT THE SYNC PHONE CALL VOLUME TOO LOUD OR TOO SOFT. DO NOT REPLACE OR UPGRADE THE ACCESSORY PROTOCOL INTERFACE MODULE (APIM). THIS CONCERN IS DEVICE DEPENDANT. PLEASE SET THE CALL VOLUME ON THE DEVICE AFTER IT IS PAIRED TO THE SYNC SYSTEM. THIS WILL ALLOW THE CALL VOLUME TO STAY THE SAME FOR ALL CALLS AFTER PAIRING.
2976 - REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND 2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP. THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
2973 - 2008-2010 F-SUPER DUTY - REAR VIDEO CAMERA
SOME 2008-2010 F-SUPER DUTY VEHICLES WITH A REAR VIDEO CAMERA MAY EXHIBIT AN IMAGE WHICH IS FOGGY, CLOUDY, FUZZY, BLURRY, HAZY, HAVE BLACK SPOTS ON THE IMAGE, OR MOISTURE IN THE LENS. THIS IS THE RESULT OF WATER INTRUSION AT EITHER THE PIGTAIL OR A SPLIT HOUSING. A NEW SERVICE PART IS NOW AVAILABLE 9C3Z-19G490-D TO RESOLVE THIS ISSUE. REFERENCE WORKSHOP MANUAL SECTION 413-13 FOR REAR VIDEO CAMERA INSTALLATION INSTRUCTIONS.
2958 - 2008-2010 E-SERIES 150-350 MODIFIED VEHICLES - STEERING WANDER
SOME 2008-2010 E-SERIES 150-350 VEHICLES THAT HAVE BEEN MODIFIED BY QUALIFIED VEHICLE MODIFIERS INTO RV MOTORHOMES MAY EXHIBIT THE STEERING WANDER ADDRESSED IN TSB 9-20-7. EVEN THOUGH THE VEHICLES HAVE BEEN MODIFIED FROM THEIR ORIGINAL PRODUCTION CONFIGURATION, THE TSB IS STILL APPLICABLE AFTER VERIFYING THE FRONT AND REAR GAWR (GROSS AXLE WEIGHT RATING) AND THE GVWR (GROSS VEHICLE WEIGHT RATING) DO NOT EXCEED THE SPECIFICATIONS ON THE VEHICLE CERTIFICATION LABEL. WEIGHING THE VEHICLE TO CONFIRM CONFORMITY WITH THE GAWR/GVWR IS HIGHLY RECOMMENDED PRIOR TO PERFORMING THE TSB. THE TSB IS NOT APPLICABLE TO VEHICLES THAT HAVE HAD STEERING AND/OR FRONT SUSPENSION MODIFICATIONS SUCH AS A LIFT KIT.
2947 - 2009-2010 E-350 AND E-450 CUTAWAY - FUSE 1.76 AND DTCS CAUSED BY HARNESS CHAFING
SOME 2009-2010 E-350 AND E-450 CUTAWAY VEHICLES MAY EXPERIENCE FUSE 1.76 FAILING INTERMITTENTLY AND MAY ALSO BE ACCOMPANIED DIAGNOSTIC TROUBLE CODES P0102, P0135, P0141, P0443, P0155 OR OTHER RELATED CODES. THIS MAY BE CAUSED BY SOME BODY BUILDERS INSTALLING THEIR OWN CROSSMEMBER ABOVE THE ORIGINAL EQUIPMENT CROSSMEMBER AND CHAFING/DAMAGING THE CATALYST MONITOR WIRING HARNESSS. IF DAMAGE TO THIS HARNESS IS FOUND, REPAIR AND REPOSITION THE WIRE HARNESS FOLLOWING NORMAL SERVICE PROCEDURES. THIS REPAIR IS THE RESPONSIBILITY OF THE BODYBUILDER AND IS NOT COVERED BY FORD WARRANTY.
2913 - PASSENGER AIRBAG TRIM COVER - SERVICEABLE SEPARATELY - DOES NOT REQUIRE COMPLETE PASSENGER AIRBAG MODULE REPLACEMENT
THE TRIM COVER FOR THE PASSENGER AIR BAG (PAB) MODULE IS SERVICEABLE SEPARATELY ON 2005-2007 FREESTYLE, 2008-2010 F-SUPER DUTY AND ESCAPE/MARINER, 2007-2010 EXPEDITION/NAVIGATOR AND EDGE, 2004-2010 ECONOLINE AND RANGER, 2006-2009 FUSION/MILAN/MKZ, AND 2005-2010 MUSTANG VEHICLES. CUSTOMER CONCERNS WITH THE TRIM COVER APPEARANCE, FIT OR FINISH CAN NOW BE RESOLVED BY REPLACING THE TRIM COVER ONLY. THE ONLINE VERSION OF THE WORKSHOP MANUAL HAS BEEN UPDATED AND INCLUDES A VIDEO JOB AID TO HELP CLARIFY THE PROCEDURE. THE SERVICE KIT BASE PART NUMBER IS -04338-. REPLACEMENT OF THE ENTIRE PAB MODULE IS NO LONGER NECESSARY TO RESOLVE TRIM COVER APPEARANCE ISSUES.
2911 - 2008-2010 F-SUPER DUTY AND 2009-2010 F-150 - TAILGATE STEP SERVICE PARTS AVAILABLE
2008-2010 F-SUPER DUTY AND 2009-2010 F-150 EQUIPPED WITH OPTIONAL TAILGATE STEP. INDIVIDUAL COMPONENTS TO SERVICE THE TAILGATE STEP IN DETAIL ARE AVAILABLE. SERVICE KIT PART NUMBER 9C3Z-99402K19-A CONTAINS ONE (1) EACH OF THE FOLLOWING COMPONENTS: ROLLER ASSEMBLY, HINGE PIVOT PIN, STEP RAIL SLIDER, AND INSTRUCTION SHEET. REFER TO THE INSTRUCTION SHEET FOR SERVICE DETAILS.
2904 - 2008-2010 F-SUPER DUTY - P2463 AND P246C CODES WILL NOT CLEAR
SOME 2008-2010 F-SUPER-DUTY MAY EXHIBIT DIAGNOSTIC TROUBLE CODES P2463(DPF RESTRICTION-SOOT ACCUMULATION) AND/OR P246C(DPF RESTRICTION- FORCED LIMITED POWER) THAT WILL NOT CLEAR USING IDS OR MAY RETURN WITHIN LESS THAN 100 MILES FOLLOWING REPLACEMENT OF THE DIESEL PARTICULATE FILTER(DPF). THIS CONCERN MAY BE DUE TO MAF SENSOR CONTAMINATION. VISUALLY INSPECT MAF SENSOR FOR DEBRIS (DIRT/OIL) AND FOREIGN OBJECTS. PERFORM MAF SENSOR PCED PIN POINT TEST J TO CONFIRM SENSOR FUNCTIONALITY. PERFORM PIN POINT TEST RB TO VALIDATE DPF FUNCTIONALITY. CONFIRM AIR FILTER, FILTER LID, PCV PORT AND ALL ATTACHING HARDWARE ARE CORRECTLY INSTALLED AND LATCHED. ENGINEERING INVESTIGATION IN PROGRESS. MONITOR OASIS FOR FUTURE UPDATES.
2901 - 2006-2010 MULTIPLE VEHILCES WITH SIRIUS "UNSUBSCRIBED" STATED ON THE AUDIO UNIT
SOME 2006-2010 VEHICLES MAY HAVE AN AUDIO UNIT STATING "UNSUBSCRIBED". THIS INDICATES THAT THE ELECTRONIC SERIAL NUMBER (ESN) IN THIS VEHICLE DOES NOT HAVE A CURRENT SUBSCRIPTION WITH SIRIUS. PLEASE CALL SIRIUS (888-539-7474) WITH THE ESN NUMBER FROM THE SATELLITE DIGITAL AUDIO RECEIVER SYSTEM, (SDARS) MODULE TO MAKE SURE THAT THE ESN NUMBER IS ASSOCIATED TO THIS VEHICLE AS WELL AS MAKING SURE THE CUSTOMERS ACCOUNT IS VALID. UNLESS THE WORK SHOP MANUAL DIAGNOSIS IS DIRECTING TO DO SO, MODULE REPLACEMENT IS NOT NEEDED FOR THIS CONCERN.
2900 - DEALER INSTALLED AUDIO UPGRADES
REPLACING THE STOCK AUDIO SYSTEM WITH A REGULAR PRODUCTION OPTION NAVIGATION/SIRIUS/SYNC AUDIO SYSTEM IS NOT RECOMMENDED OR SUPPORTED ON ANY FORD, MERCURY OR LINCOLN VEHICLE. HOWEVER GENUINE FORD ACCESSORY KITS TO INSTALL SYNC ARE AVAILABLE FOR CERTAIN MODEL LINES. REFER TO FMCDEALER/ ACCESSORIES, FOR THE APPLICABLE KIT PART NUMBER. A DEALER INSTALLED FORD WORKS SOLUTIONS IN-DASH COMPUTER KIT WITH NAVIGATION IS AVAILABLE FOR CERTAIN E-SERIES, F-SERIES AND TRANSIT CONNECT VEHICLES. REFER TO FMCDEALER/ACCESSORIES/OFFICIAL LICENSED PRODUCT/FORD WORK SOLUTIONS, FOR THE APPLICABLE KIT PART NUMBER.
2899 - 2006-2010 MULTIPLE VEHILCES WITH RADIO AND/OR SATELLITE RADIO INOPERATIVE OR DIAGNOSTIC TROUBLE CODES
SOME 2006-2010 VEHICLES MAY EXHIBIT A RADIO AND/OR SATELLITE RADIO INOPERATIVE WITH OR WITHOUT DIAGNOSTIC TROUBLE CODES (DTCS). BE SURE TO VERIFY WHICH MODULE SET THESE CODES OR ARE INOPERATIVE. IF THE DTC IS SET IN THE SATELLITE DIGITAL AUDIO RECEIVER SYSTEM (SDARS) BE ADVISED THAT THIS MAY OR MAY NOT BE A STAND ALONE MODULE. REFER TO THE ONLINE WORK SHOP MANUAL SECTION 415-00 FOR DIAGNOSTIC PROCEDURES. IF THE DTC IS SET IN THE AUDIO CONTROL MODULE (ACM), REFER TO THE ONLINE WORK SHOP MANUAL SECTION 415-00. DIAGNOSE THE CORRECT MODULE THAT THE CONCERN OR DTC CODE WAS SET IN.
2898 - SOME 2008-2010 SUPER DUTY - 6.4L DIESEL ENGINES - REPEAT RADIATOR LEAK - BUILT ON OR BEFORE 9/14/2009
SEE TSB 09-23-01 FOR DETAIL 09-23-01
2886 - 6.0L DIESEL-DRIVEABILITY-NO START/HARD START/LONG CRANK/MISFIRE/RUNS ROUGH/LACK OF POWER/BUCK/JERK OR EXCESSIVE EXHAUST SMOKE DIAGNOSIS
SEE TSB 09-22-16 FOR DETAIL 09-22-16
2863 - REVISIONS TO THE DIESEL ENGINE COMPONENTS PRIOR APPROVAL PROGRAM BEGIN 11/2/09
THE EXISTING DIESEL ENGINE COMPONENTS PRIOR APPROVAL PROGRAM IS BEING AMENDED TO REMOVE FOUR 6.0L COMPONENTS, AND ADD ONE NEW 6.0L AND TWO NEW 6.4L COMPONENTS. THESE REVISIONS APPLY TO BOTH LEVEL 1 AND LEVEL 2 DEALERSHIPS AND ARE EFFECTIVE WITH REPAIR ORDERS DATED ON OR AFTER NOVEMBER 2, 2009. IN ADDITION, THE PRIOR APPROVAL REQUIREMENTS TABLE HAS BEEN UPDATED TO REFLECT THESE REVISIONS. REFER TO THE FOLLOWING DEALER LETTER FOR MORE INFORMATION: DEALER LETTER, DATED OCTOBER 12, 2009 "REVISIONS TO THE EXISTING DIESEL ENGINE COMPONENTS PRIOR APPROVAL PROGRAM"
2777 - 2009-2010 F-SUPER DUTY 6.4L DRW AND 6.8L DRW - 2" HITCH ADAPTER AND PIN NO LONGER INCLUDED WITH 15K BUILT FORD TOUGH TRAILER HITCH RECEIVER IN PRODUCTION
2009-2010 F-SUPER DUTY VEHICLES EQUIPPED WITH 6.4L DUAL REAR WHEELS (DRW) OR 6.8L DRW NO LONGER INCLUDES THE 2" HITCH ADAPTER AND PIN FOR THE 2 1/2" OR 15K BUILT FORD TOUGH TRAILER HITCH RECEIVER. DO NOT INSTALL THE 2" HITCH ADAPTER (P/N 5C3Z 19H282 AB) OR PIN KIT (P/N 5C3Z 19A326 A), AS THIS IS NO LONGER A PART OF THE TRAILER HITCH PACKAGE AND IS A NON-WARRANTABLE ITEM. THE 2" HITCH ADAPTER AND PIN KIT ARE STILL AVAILABLE TO THE CUSTOMER THROUGH FORD PARTS AND SERVICES.
2771 - 2005-2010 F-SUPER-DUTY WITH 5.4 AND 6.8 ENGINES - SLOW FUEL FILL
SEE TSB 09-20-12 FOR DETAIL 09-20-12
2765 - TRAILER BRAKE CONTROL WIRING PIGTAIL, TRAILER BATTERY CHARGE RELAY AND FUSE KITS
2010 F-150 VEHICLES EQUIPPED WITH OPTIONAL TRAILER BRAKE CONTROL (TBC) ARE SHIPPED FROM THE FACTORY WITH TRAILER BATTERY CHARGE RELAY AND FUSE, KIT NUMBER AL3T-15A416-AA. VEHICLES EQUIPPED WITH OPTIONAL TBC DO NOT REQUIRE WIRING PIGTAIL CONNECTOR FOR CUSTOMER INSTALLED AFTERMARKET TBC. VEHICLES EQUIPPED WITH OPTIONAL TRAILER TOW PACKAGE, BUT NOT EQUIPPED WITH OPTIONAL TBC CONTINUE TO BE SHIPPED FROM THE FACTORY WITH A WIRING PIGTAIL CONNECTOR FOR CUSTOMERS TO INSTALL AFTERMARKET TBC, KIT NUMBER 9L3T-15A416-AD. THESE KITS ALSO INCLUDE TRAILER BATTERY CHARGE RELAY AND FUSE.
2758 - 2008-2010 E-SERIES STEERING WANDER
SEE TSB 09-20-07 FOR DETAIL 09-20-07
2753 - 2008-2010 F-SUPER DUTY 250/350 SINGLE REAR WHEEL (SRW) AND F-350 DUAL REAR WHEEL (DRW) - SHUDDER OR VIBRATION ON ACCELERATION - ESPECIALLY WHEN LOADED
SEE TSB 09-20-05 FOR DETAIL 09-20-05
2745 - IDS 6.0L DIESEL CAM TIMING DIAGNOSTIC TOOL
IDS RELEASE R63 FEATURES A NEW TOOL; "DIESEL CAM TIMING". THIS FEATURE AIDS IN ISOLATING RELATIVE CAM TIMING CONCERNS OR IF FAULTS EXISTS WITH THE CKP OR CMP SIGNALS. SYMPTOMS OF CKP OR CMP SIGNAL FAULTS MAY INCLUDE CRANK/NO-START, REPEATED CRANK/START/STALL WITH MUFFLED COMBUSTION NOISE AND EXCESSIVE WHITE EXHAUST SMOKE, SYNC OR FICM SYNC PID'S READING 'NO', AND DTC'S P0341, P2614 OR P2617. THIS TEST IS AVAILABLE UNDER THE FOLLOWING MENU CASCADE; IDS TOOLBOX - OSCILLOSCOPE TOOLS - DIESEL CAM TIMING. AFTER ENTERING THE TEST, SELECT EITHER HOOKUP METHOD 1 OR 2 BY CLICKING WITHIN THE TEXT ON THE LEFT SIDE OF THE SCREEN FOR HOOKUP GRAPHICS. FOR MORE DETAILS, WAVEFORMS, ILLUSTRATIONS AND INFORMATION ABOUT APPLYING THE TEST TO 6.0L HEAVY DUTY APPLICATIONS, 4.5L AND 6.4L, REFER TO PTS 'SERVICE TIPS' TAB OF THE VEHICLE BEING SERVICED.
2744 - 2008-2010 F-SUPER DUTY EQUIPPED WITH 6.4 - BUCK/JERK, SURGE TOWING 5TH WHEEL AND GOOSENECK TRAILERS.
SOME 2008-2010 F-SERIES SUPER-DUTY VEHICLES EQUIPPED WITH 6.4L DIESEL ENGINES MAY EXHIBIT A BUCK/JERK OR SURGE CONDITION WHEN TOWING 5TH WHEEL OR GOOSENECK TRAILERS. ANALYSIS OF FIELD REPORTS REVEALS THAT THIS CONDITION IS NOT OCCURRING WITH THE VEHICLE IN CRUISE CONTROL MODE. PREVIOUS INVESTIGATIONS FOR THIS CONDITION INDICATE THAT VEHICLES EQUIPPED WITH ADJUSTABLE PEDALS ARE MORE LIKELY TO EXPERIENCE THIS CONCERN WITH THE PEDALS ADJUSTED ALL THE WAY UP, DUE TO CUSTOMERS UNKNOWINGLY TIPPING IN AND OUT OF THE PEDAL WHEN VEHICLE/TRAILER BUCK JERK INTERACTION OCCURS. THIS CONDITION IS MORE NOTICEABLE ON AUTOMATIC TRANSMISSIONS EQUIPPED VEHICLES BUT MAY ALSO OCCUR ON MANUAL TRANSMISSIONS, IT CAN ALSO BE PERPETUATED BY AFTERMARKET HITCH INTERACTION. ENGINEERING IS CURRENTLY INVESTIGATING FIELD REPORTS.
2743 - MULTIPLE VEHICLE LINES - USE OF AFTERMARKET LAMPS - DO NOT USE HIGH WATTAGE BULBS
SEVERAL AFTERMARKET COMPANIES OFFER REPLACEMENT HEADLAMP BULBS OF A HIGHER WATTAGE RATING THAN OEM STOCK BULBS. THESE BULBS ARE NOT DOT APPROVED AND ARE TYPICALLY SOLD WITH THE DISCLAIMER OF 'FOR OFF-ROAD USE ONLY'. IN ADDITION TO POSSIBLY BEING ILLEGAL FOR STREET USE, THE BULBS ALSO DRAW MUCH MORE CURRENT THAN OEM BULBS. THIS INCREASED CURRENT CAN RESULT IN ACTUATION OF THE SHORT-CIRCUIT PROTECTION FEATURE (LOOKING LIKE BULB BURNOUT), OR DAMAGE TO THE HEADLAMP SWITCH, MULTIFUNCTION SWITCH, WIRING, WIRING CONNECTORS, OR EVEN THE HEADLAMP ASSEMBLIES THEMSELVES. THESE HIGH-WATTAGE AFTERMARKET BULBS SHOULD BE REPLACED WITH OEM BULBS, AND CUSTOMERS ADVISED NOT TO USE THEM.
2736 - SOME 2009 F-SUPER DUTY VEHICLES EQUIPPED WITH 5.4L OR 6.8L ENGINE AND TORQSHIFT TRANSMISSION, MAY EXHIBIT MINOR TRANSMISSION LEAK.
SOME 2009 F250-F550 SUPER DUTY EQUIPPED WITH 5.4L OR 6.8L AND TORQSHIFT TRANSMISSION, MAY EXHIBIT A SMALL TRANSMISSION FLUID LEAK. THE LEAK MAY BE CAUSED BY A TRANSMISSION FLUID OVERFILL CONDITION. INSTALL IDS TO READ (TFT) TEMPERATURE. CHECK FLUID LEVEL AT NORMAL OPERATING TEMPERATURE 150-170F (66-77C) AS PER WORKSHOP MANUAL SECTION 307-01 CHECK TRANSMISSION FLUID LEVEL AND CONDITION. IF AN OVERFILL READING IS INDICATED, REFER TO WORKSHOP MANUAL SECTION 307-01 TRANSMISSION FLUID DRAIN AND REFILL, AND ADJUST FLUID LEVEL TO THE CENTER OF THE NORMAL OPERATING TEMPERATURE RANGE (HASH MARK AREA MARKED WITH AN "H" ON THE FLUID LEVEL INDICATOR).
20982 6.0L CORROSION RESISTANT CENTER HOUSING ROTATING ASSEMBLY (CHRA) AND TURBO ASSEMBLIES
ALL REMANUFACTURED 6.0L TURBOCHARGERS AND CHRA'S BUILT AFTER 8/24/09 WILL NOW INCORPORATE A NEW CORROSION RESISTANT SURFACE TREATMENT (CRST) AND MAY USE EITHER A NON-RECESSED OR RECESSED CENTER HOUSING. THE APPEARANCE OF THE CRST PROCESSED CHRA WILL APPEAR AS A FLAT "TEFLON-LIKE" COATING AND HAVE HEAT DISCOLORATION FROM THE HEAT TREATING PROCESS. THIS IS A PRODUCT CHARACTERISTIC AND SHOULD BE CONSIDERED NORMAL. NOTE: PICTURES OF THE REVISED COATING CAN BE FOUND ON THE 'PTS' WEBSITE UNDER 'SERVICE TIPS' FOR THE AFFECTED VEHICLE LINES.
EFFECTIVE DATE: 09/16/2009
20451 2004-2008 E-SERIES/2003-2007 F-SUPER DUTY/2003-2005 EXCURSION/2006-2009 LOW CAB FORWARD/2004-2007 F650-F750 - OIL COOLER SERVICE TIP
SOME 6.0L AND 4.5L DIESEL EQUIPPED VEHICLES MAY EXPERIENCE VARIOUS DRIVEABILITY SYMPTOMS AFTER OIL COOLER SERVICE. THIS MAY BE THE RESULT OF THE IPR BECOMING CONTAMINATED AND BEING UNABLE TO CONTROL ICP PROPERLY. IT IS STRONGLY RECOMMENDED TO COMPLETELY CLEAN OFF ALL OIL AND DEBRIS PRIOR TO OIL COOLER COVER REMOVAL AND TO INSPECT THE OIL PUMP INLET STRAINER SCREEN FOR DAMAGE PRIOR TO OIL COOLER REPLACEMENT. IF THE SCREEN IS DAMAGED, IT MUST BE REPLACED. THE RESERVOIR MUST BE COMPLETELY CLEANED TO ENSURE THERE IS NO CONTAMINATION TO THE HIGH PRESSURE OIL SYSTEM FROM DEBRIS ENTERING THE OIL DURING OIL COOLER REPLACEMENT. AFTER CLEANING, PRE-FILLING THE RESERVOIR WITH CLEAN OIL WILL HELP PREVENT EXTENDED CRANK TIME FROM AIR ENTERING THE HIGH PRESSURE OIL SYSTEM UPON ASSEMBLY.
EFFECTIVE DATE: 09/17/2008
20370 1999-2008 7.3L/6.0L/6.4L/4.5L DIESEL - CLEAN THE CHARGE AIR COOLER (CAC) SYSTEM AFTER CERTAIN TURBO OR ENGINE FAILURES - SERVICE TIP
ON A 7.3L, 6.0L, 6.4L, OR 4.5L DIESEL EQUIPPED VEHICLE IF THE TURBOCHARGER IS REPLACED FOR AN INTERNAL OIL LEAK OR COMPRESSOR SHAFT FAILURE, THE CHARGE AIR COOLER (CAC) SHOULD BE CHECKED FOR OIL CONTAMINATION AND CONSEQUENTLY CLEANED IF CONTAMINATION IS FOUND. THE CAC SHOULD ALSO BE INSPECTED AND CLEANED OF OIL, FUEL, OR METAL CONTAMINATION AFTER AN ENGINE FAILURE THAT MAY HAVE PUSHED OIL, FUEL, OR METAL INTO THE CAC DUE TO EXCESSIVE CRANKCASE PRESSURE. A THOROUGH CLEANING OF THE CAC SYSTEM IS NECESSARY TO PREVENT ENGINE DAMAGE OR DRIVABILITY CONCERNS. REFER TO THE WORKSHOP MANUAL SECTION 303-12 FOR PROPER CAC CLEANING PROCEDURES. IF EXHAUST SMOKE IS OBSERVED AFTER ENGINE REPAIRS AND THE CAC CLEANING HAVE BEEN COMPLETED REFER TO SYMPTOM CHART 8 IN THE PCED MANUAL.
EFFECTIVE DATE: 08/05/2008
2590 - ANNOUNCING SAFETY COMPLIANCE RECALL 09C08 - SUPPLEMENT #1
DEMONSTRATION / DELIVERY HOLD - COMPLIANCE RECALL 09C08 - SUPPLEMENT #1:CERTAIN 2008 AND 2009 MODEL YEAR E-350/450 VEHICLES EQUIPPED WITH SCHOOL BUS PREP PACKAGE - FUEL TANK PROTECTION BRACKET INSPECTION. THIS HAS BEEN POSTED TO FMCDEALER.COM.
2585 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BETWEEN 8/3/2007 AND 1/2/2008 - MODULE REPROGRAMMING
SEE TSB 09-16-10 FOR DETAIL 09-16-10
2584 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT PRIOR TO 8/2/2007 - MODULE REPROGRAMMING
SEE TSB 09-16-09 FOR DETAIL 09-16-09
2556 - 2008-2010 F-SUPER-DUTY 6.4L DIESEL ENGINE TICKING/TAPPING NOISE
SEE TSB 09-16-02 FOR DETAIL 09-16-02
2550 - NEW IDS DIAGNOSTIC TEST CAPABILITY
BEGINNING WITH IDS VERSION 62 RELEASE, 2 NEW TOOLBOX OSCILLOSCOPE PCM DRIVER TEST FEATURES, "PCM IGNITION COIL DRIVER TEST" AND PCM INJECTOR DRIVER TEST", WILL BE AVAILABLE FOR SELECT 2006 AND LATER MODEL YEAR VEHICLES. THESE TESTS WILL PROVIDE THE TECHNICIAN A METHOD TO MONITOR THE COIL CHARGE CURRENT, AS WELL AS THE INJECTOR CURRENT, TO VERIFY THE INTERNAL PCM DRIVER CIRCUITS ARE FUNCTIONING CORRECTLY. HELP FILES ARE INCLUDED IN THE TOOL TO ASSIST IN HOOKUP, DIAGNOSTIC THEORY AND NORMAL VS. FAULTED DRIVER PATTERNS
2548 - 2008-2009 F-SUPER DUTY - SLIDING POWER WINDOW (BACK GLASS) INOPERATIVE OR BINDING VEHICLES BUILT BEFORE 6/20/2009
SEE TSB 09-15-11 FOR DETAIL 09-15-11
20922 - 2008-2010 F-SUPER DUTY - RADIATOR COOLANT LEAKS AND PCM CONTROLLED DERATE STRATEGY DUE TO HYPER EXTENDED THERMOSTATS
SOME 2008-2010 SUPER DUTIES WITH 6.4L DIESEL ENGINES MAY EXHIBIT A LACK OF POWER WITHOUT DIAGNOSTIC TROUBLE CODES(DTCS), HIGH TEMPERATURE GAUGE READINGS AND REDUCED ENGINE POWER(PCM DERATE STRATEGY DESIGNED FOR ENGINE TEMPERATURE PROTECTION) DUE TO MALFUNCTIONING THERMOSTATS. DIAGNOSE BY MONITORING ENGINE OIL TEMPERATURE(EOT) AND ENGINE COOLANT TEMPERATURE(ECT) PIDS WITH IDS TOOL. WITH EOT AT 195 DEGREES F(90C) DRIVE UNLOADED VEHICLE AT 55-70MPH(88-(112 KPH) STEADY STATE SPEED WHILE OBSERVING EOT AND ECT TEMPS. IF EOT IS LESS THAN 8 DEGREES F(4.4C) HIGHER THAN ECT, AND THE COOLANT TEMP FLUCTUATES APPROXIMATELY 5 DEGREES(2.7C), THE THERMOSTATS ARE FUNCTIONING PROPERLY. ONLY REPLACE THERMOSTATS(8C3Z-8575-C)IF EOT EXCEEDS ECT BY GREATER THAN 8 DEGREES F(4.4C) OR IF ECT READINGS FLUCTUATE 10 TO 12 DEGREES(5-6C) EVERY 30 SECONDS.
EFFECTIVE DATE: 07/30/2009
2489 - REVISED BRAKE BLEED PROCEDURE, MERITOR WABCO BRAKE SYSTEM - UPDATED IN WORK SHOP MANUAL
REVISED BRAKE BLEED PROCEDURE HAS BEEN UPDATED IN THE WORKSHOP MANUAL. THE CONTENTS OF TSB 08-25-11 HAVE BEEN UPDATED AND INCLUDED IN THE ONLINE VERSION OF THE WORK SHOP MANUAL. WHEN PERFORMING SERVICE WORK ON THE MERITOR WABCO BRAKE SYSTEM, PLEASE REFER TO THE ONLINE WORKSHOP MANUAL SECTION 206-00A. READ AND UNDERSTAND THE COMPLETE BRAKE BLEED PROCEDURE BEFORE STARTING THE BLEED PROCESS.
2488 - WABCO BRAKES SOFTWARE VERSION - USE 8.9.8 VERSION OR LATER
F650/750 TRUCKS EQUIPPED WITH FULL POWER HYDRAULIC BRAKES NEED TO BE DIAGNOSED USING WABCO SOFTWARE VERSION 8.9.8 OR LATER. ANY SOFTWARE PRIOR TO THIS VERSION MAY NOT PROVIDE FULL DIAGNOSTIC CAPABILITIES FOR THIS SYSTEM. THIS SOFTWARE IS AVAILABLE VIA FMCDEALER.COM WITHIN THE ROTUNDA LINK AT THE MD TRUCK SITE. TO DOWNLOAD GO DIRECTLY TO STEP 5 AS LONG AS YOU ALREADY HAVE THE LAUNCH PAD LOADED.
2477 - 2009 E-SERIES: U0109 - POOR GROUND CONNECTION
SOME 2009-2010 E-SERIES VEHICLES MAY EXHIBIT A CRANK/NO-START CONDITION WITH DTC U0109 (LOST COMMUNICATION WITH FUEL PUMP CONTROL MODULE) OR THE FUEL GAUGE DROPPING TO "E" WHEN THE ENGINE IS RUNNING. DTC P0463 (FUEL LEVEL SENSOR CIRCUIT HIGH) MAY ALSO BE PRESENT. THIS MAY BE CAUSED BY THE BODY TO FRAME GROUND STRAP. THE F2UZ-19A095-A GROUND STRAP IS LOCATED IMMEDIATELY BENEATH THE PASSENGER SIDE B-PILLAR. ENSURE BOTH ATTACHMENT POINTS ARE CLEAN OF PAINT/CORROSION AND THE FASTENERS ARE PROPERLY TORQUED BEFORE SERVICING ANY FUEL OR ELECTRICAL SYSTEM COMPONENTS.
2435 - ANNOUNCING FSA 08B06 SUPPLEMENT #2 - PROGRAM EXTENSION CUSTOMER SATISFACTION PROGRAM 08B06-S#2:
CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE COOLING SYSTEM VENTURI TEE INSTALLATION. PROGRAM EXTENSION TO 12/31/09. THIS HAS BEEN POSTED TO FMCDEALER.COM
2433 - 2008-2009 F-SUPER DUTY - 6.4L REPEAT FRONT CRANKSHAFT SEAL LEAKS
SOME 2008-2009 6.4L DIESEL EQUIPPED VEHICLES MAY EXHIBIT WHAT APPEARS TO BE AN OIL LEAK AT THE FRONT CRANKSHAFT OIL SEAL. IF THE FRONT CRANKSHAFT SEAL REQUIRES SERVICE, THE SEAL AND WEAR SLEEVE MUST BE INSTALLED TOGETHER USING THE PROPER SERVICE TOOLS. REFERENCE WORKSHOP MANUAL SECTION 303-01C FOR DETAILS. ENGINEERING REVIEW OF REPEAT FRONT SEAL WARRANTY CLAIMS HAS CONCLUDED THAT OTHER EXTERNAL ENGINE OIL LEAKS ARE BEING MISDIAGNOSED AS FRONT CRANK SEAL OIL LEAKS. TO PROPERLY DETERMINE IF THE LEAK IS FROM THE FRONT SEAL, CLEAN/WIPE THE SEAL AND FRONT COVER AREA AND ADD 3OZ OF OIL DYE TO THE ENGINE OIL. RUN VEHICLE UNTIL IT REACHES NORMAL ENGINE OPERATING TEMPERATURE AND INSPECT FOR LEAKS USING A BLACK LIGHT. REPAIR AS NECESSARY.
2396 - 2009-2010 F-150 AND F-SUPER DUTY - FORD WORK SOLUTIONS CABLE LOCK
SOME 2009-2010 F-150 AND F-SUPER DUTY VEHICLES MAY COME EQUIPPED WITH AN OPTIONAL CABLE LOCK FEATURE IN THE BED. IF THE CABLE LOCK NEEDS TO BE TEMPORARILY REMOVED, REFER TO THE ACCESSORIES SECTION OF FMCDEALER.COM THE INSTALLATION INSTRUCTIONS ARE LOCATED IN THE FORD LICENSED ACCESSORIES SECTION. THE A9FCS-4FW603-AA CABLE LOCK CAN ALSO BE INSTALLED AS AN ACCESSORY ON VEHICLES NOT ORIGINALLY EQUIPPED.
2395 - 1999-2009 MULTIPLE VEHICLES - FLUTTER/TURBULENCE NOISE AT HIGHWAY SPEEDS WITH REAR WINDOWS OR MOON/SUN ROOF OPEN
SOME 1999-2009 VEHICLES MAY EXHIBIT A FLUTTER/TURBULENCE NOISE (HELICOPTER NOISE) AT HIGHWAY SPEEDS WHEN THE REAR DOOR WINDOW(S) OR SUN/MOON ROOF ARE OPEN. THIS CONDITION IS A CHARACTERISTIC OF THE VEHICLE BODY DESIGN AND IS ALSO A CHARACTERISTIC OF COMPETITIVE VEHICLES WITH A SIMILAR BODY STYLE. THIS CONDITION CAN BE REDUCED BY LOWERING EITHER ONE, OR BOTH, OF THE FRONT WINDOWS AT LEAST 2 INCHES. NO SERVICE ACTION IS RECOMMENDED FOR THIS CONDITION.
2392 - MULTIPLE VEHICLE LINE NAVIGATION SCREEN PICTURE TURNED SIDEWAYS OR UPSIDE DOWN
SOME 2009 AND 2010 FORD, LINCOLN AND MERCURY VEHICLES WITH NAVIGATION SYSTEMS MAY HAVE A SYMPTOM OF THE NAVIGATION SCREEN PICTURE BEING TURNED SIDEWAYS OR UPSIDE DOWN. PLEASE REFER TO THE PROPER PAGE OF THE VEHICLES NAVIGATION OWNERS GUIDE FOR THE PICTURE ROTATE PROCEDURE. NOTE: NO COMPONENT REPLACEMENT IS REQUIRED FOR THIS CONCERN.
2364 - 2006-2009 LCF - A/C STOPS BLOWING COLD AIR - A/C REFRIGERANT LEAKS UNDER INSTRUMENT PANEL
SEE TSB 09-12-09 FOR DETAIL 09-12-09
2352 - 2003-2007 F-SUPER DUTY/2003-2005 EXCURSIONS/2004-2008 E-350/450 - 6.0L TURBOCHARGER CARBON DEPOSIT DIAGNOSTICS AND SERVICE TIPS
SEE TSB 09-12-02 FOR DETAIL 09-12-02
2348 - 2008-2010 SYNC - USB PORT INOPERATIVE DURING OR AFTER APPLE IPOD TOUCH INSTALLED IN USB PORT
SOME 2008-2010 SYNC EQUIPPED VEHICLES MAY EXHIBIT THE USB PORT INOPERATIVE DURING OR AFTER AN APPLE IPOD TOUCH WAS USED IN THE USB PORT. ENGINEERING IS CURRENTLY INVESTIGATING THIS CONCERN. IF VERIFIED, PERFORM A POWER RESET ON THE ACCESSORY PROTOCOL INTERFACE MODULE (APIM) BY DISCONNECTING THE VEHICLE BATTERY FOR 3 MINUTES. REPROGRAMMING OR REPLACING THE APIM IS USUALLY NOT NECESSARY TO RETURN FUNCTIONALITY TO THE USB PORT IF IPOD TOUCH IS THE SOURCE OF THE CONCERN. IF CONCERN IS ONLY PRESENT WHEN USING THE IPOD TOUCH, IT IS RECOMMENDED THE CUSTOMER NO LONGER USE THAT DEVICE IN THE USB PORT UNTIL A DEVICE FIRMWARE UPGRADE FROM THE MANUFACTURER OR AN APPLICABLE SYNC UPDATE IS AVAILABLE. WHEN DOCUMENTING THE WARRANTY CLAIM, PLEASE LIST ANY DEVICE INFORMATION TO ASSIST WITH ENGINEERING INVESTIGATION.
2345 - 2008-2009 F-SUPER DUTY EXTERIOR DOOR HANDLE LOOSE - BUILT BEFORE 11/01/2008
SEE TSB 09-12-01 FOR DETAIL 09-12-01
2343 - 2008 SYNC - DIAGNOSTIC TROUBLE CODE (DTC) PROTOCOL CHANGE AFTER VERSION 2 - 911 ASSIST AND VEHICLE HEALTH REPORT UPGRADE
SOME 2008 VEHICLES EQUIPPED WITH SYNC MAY HAVE HAD A CUSTOMER-PAID ENHANCEMENT/REFLASH PERFORMED TO ADD THE 911 ASSIST AND VEHICLE HEALTH REPORT FEATURE. THE VEHICLE ACCESSORY PROTOCOL INTERFACE MODULE (APIM) WILL NOW SET THE NEW PROTOCOL DIAGNOSTIC TROUBLE CODES (DTC) - (EXAMPLE: U3003:16) WHICH ARE NOT SUPPORTED IN THE 2008 DIAGNOSTICS. IF A NEW PROTOCOL DTC IS RETRIEVED FROM A 2008 MODEL YEAR APIM, REFERENCE THE 2009 WORKSHOP MANUAL, SECTION 415-00 TO DIAGNOSE.
2336 - 2008 F-SUPER DUTY SEAT SIDE TRIM PANEL LOOSE / BROKEN / CRACKED - BUILT BEFORE 8/1/2008
SEE TSB 09-11-16 FOR DETAIL 09-11-16
2331 - 2008-2009 F650/750 - AIR SEAT LUMBAR OPERATION
ON 2008-2009 F650/750 SUPER DUTY VEHICLES WHEN INFLATING AND DEFLATING THE AIR SEAT LUMBAR AN AIR LEAK CAN BE HEARD COMING FROM ITS SWITCH. THIS LEAK IS PART OF THE RELIEF VALVE FUNCTION. DO NOT ATTEMP ANY REPAIR.
2328 - SYNC SOFTWARE UPDATE - VERSION 3.0 - SYNC TRAFFIC, DIRECTIONS, AND INFORMATION FEATURES - US ONLY[/b]
SEE TSB 09-11-14 FOR DETAIL 09-11-14
2282 - 2001-2009 F-SUPER DUTY 650/750 - TRAILER LAMPS / BACKUP ALARM INOPERATIVE
SEE TSB 09-10-05 FOR DETAIL 09-10-05
2268 - 2008-2009 F-SUPER DUTY - RADIATOR COOLANT LEAKS
ENGINEERING IS CURRENTLY INVESTIGATING SOME 6.4L DIESEL EQUIPPED VEHICLES THAT EXHIBIT A RADIATOR COOLANT LEAK DUE TO MALFUNCTIONING THERMOSTATS. USE AN IDS AND MONITOR ENGINE OIL TEMPERATURE (EOT) AND ENGINE COOLANT TEMPERATURE (ECT) PIDS. WITH EOT AT 195 DEG. F (90 DEG. C) DRIVE ON THE HIGHWAY UNLOADED AT 55-70 MPH (88-112 KPH) CONSTANT SPEED TO OBSERVE EOT AND ECT TEMP. IF EOT IS LESS THAN 8 DEG. F (4.4 DEG. C) HIGHER THAN ECT, AND THE COOLANT TEMP FLUCTUATES ROUGHLY 5 DEG. F (2.7 DEG. C), THE THERMOSTAT IS OK. ONLY REPLACE THERMOSTATS IF EOT EXCEEDS ECT BY GREATER THAN 8 DEG. F (4.4 DEG. C) OR IF THE ECT READINGS FLUCTUATE 10 TO 12 DEG. F (5.55-6.66 DEG. C) ROUGHLY EVERY 30 SECONDS. REFERENCE WORKSHOP MANUAL ENGINE COOLING SECTION 303-03 FOR THERMOSTAT REMOVAL AND INSTALLATION PROCEDURES.
2254 - 2008 F-SUPER DUTY - 6.4L DIESEL ENGINE - LACKS POWER, LEAKS FLUID FROM EXHAUST PIPE, ABNORMAL TAILPIPE SEDIMENT, WHITE SMOKE, EXHAUST SMELL AND MIL ON
SEE TSB 09-10-02 FOR DETAIL 09-10-02
2242 - 6.4L DIESEL - COLD START BELT CHIRP
SEE TSB 09-09-08 FOR DETAIL 09-09-08
2235 - 1997-2009 MULTIPLE VEHICLE - 4.6L/5.4L - ENGINE TICKING AND/OR RATTLE NOISE
MULTIPLE VEHICLE LINES WITH 4.6L OR 5.4L ENGINE MAY EXPERIENCE AN ENGINE TICKING OR RATTLE NOISE THAT SOUNDS LIKE A STUCK TAPPET (HLA). THIS MAY BE DUE TO THE DETERIORATION OF AN AFTERMARKET OIL FILTER. VEHICLES WITH THIS CONDITION HAVE LOW OIL PRESSURE AT ONE CYLINDER HEAD ONLY, WHILE MAIN PRESSURES ARE NORMAL. DISLODGED MATERIAL FROM THE AFTERMARKET OIL FILTER BLOCKS THE CAM CAP OIL PASSAGE, EITHER AT CYLINDER #4 (RIGHT BANK REAR) OR CYLINDER #5 (LEFT BANK FRONT).FOR VCT EQUIPPED ENGINES, INSPECT THE VCT VALVE BODY AND THE OIL PASSAGES UNDER THE FIRST CAM CAP. FORD RECOMMENDS THE USE OF FORD APPROVED FILTERS ONLY. DAMAGE TO ENGINES CAUSED BY AFTERMARKET OIL FILTERS ARE NOT COVERED UNDER WARRANTY.
2230 - 2008-2009 F-SUPER DUTY - STATIONARY ELEVATED IDLE CONTROL (SEIC) SERVICE TIP
TO ACCESS INFORMATION REGARDING STATIONARY ELEVATED IDLE CONTROL (SEIC) FOR 2008-2009 F-SUPER DUTY VEHICLES, PLEASE REFER TO QVM BULLETINS Q162-R1 FOR 2008 MY AND Q173 FOR 2009 MY. THESE BULLETINS CAN BE FOUND ON THE FORD FLEET WEBSITE AT HTTPS://WWW.FLEET.FORD.COM/, THEN CLICK ON SHOWROOM, THEN CLICK ON TRUCK BODY BUILDERS/UPFITTERS, THEN CLICK ON BULLETINS, SELECT F-SD, AND SELECT THE NUMBERS MENTIONED IN THIS SSM.
2227 - ANNOUNCING MAINTENANCE REMINDER 09L04
ANNOUNCING MAINTENANCE REMINDER 09L04 - CERTAIN 2003 THROUGH 2008 MODEL YEAR VEHICLES EQUIPPED WITH A 6.0L OR 6.4L DIESEL ENGINE - CUSTOMER MAINTENANCE REMINDER. THIS HAS BEEN POSTED TO FMCDEALER.COM.
2222 - 2000-2009 E-SERIES - ALIGNMENT SLEEVE AND SERVICE REPLACEMENT BALL JOINT
2000-2009 E-SERIES WHEN INSTALLING A 8C3Z-3049-B UPPER BALL JOINT THE ORIGINAL ALIGNMENT SLEEVE MAY NOT PROVIDE ADEQUATE CLEARANCE FOR INSTALLATION OF THE PINCH BOLT. THIS MAY BE DUE TO AN ADDITIONAL SHOULDER THAT HAS BEEN ADDED TO THE BALL JOINT TO PROTECT THE SEAL FROM WEAR. IF THE PINCH BOLT CANNOT BE INSERTED DUE TO INTERFERENCE AT THE BOTTOM OF THE SLOT IN THE SLEEVE, REMOVE THE SLEEVE AND GRIND 2MM (.078IN) FROM THE LOWER PORTION OF THE PINCH BOLT SLOT. IF THE PINCH BOLT INTERFERENCE IS AT THE TOP OF THE SLOT, SIMPLY RAISE THE SLEEVE 2MM (.078IN) SINCE THE SLEEVE IS NOT REQUIRED TO BE FLUSH WITH THE TOP OF THE I-BEAM AXLE FOR PROPER RETENTION AND FUNCTION.
2220 - APPEARANCE OF GRAY OR MILKY AXLE LUBRICANT
SOME 2004-2010 MUSTANG, 2004-2009 E-SERIES, F-150, F-SUPER DUTY,CROWN VIC/GRAND MARQUIS,TOWN CAR, EXPEDITION/NAVIGATOR, EXPLORER/MOUNTAINEER, EXPLORER SPORT TRAC VEHICLES EQUIPPED WITH FORD/STERLING FRONT AND/OR REAR AXLES MAY EXHIBIT AXLE LUBRICANT THAT APPEARS MILKY OR GREY. THE APPEARANCE IS MOST LIKELY DISCOLORATION CAUSED BY MARKING COMPOUND USED AT THE FACTORY TO CHECK GEAR TOOTH PATTERNS. THIS CONDITION MAY BE MORE APPARENT ON INDEPENDENT REAR AND/OR FRONT SUSPENSION AXLES AS THERE IS LESS LUBRICANT VOLUME PRESENT. THIS CONDITION HAS NO EFFECT ON THE PERFORMANCE OR DURABILITY OF THE AXLE AND IS CONSIDERED NORMAL. DO NOT CHANGE THE LUBRICANT FOR THIS CONDITION.
2201 - 6.0L & 6.4L DIESEL ENGINES CHECK NITRITE LEVELS USING ROTUNDA 3-WAY ANTIFREEZE TEST STRIP KIT #328-00001
RECENT DEALER COMMUNICATION "6.0L AND 6.4L DIESEL ENGINE MAINTENANCE" PUBLISHED 3/30/09 EXPLAINS THE IMPORTANCE OF REGULAR NITRITE LEVEL CHECKS OF THE ENGINE COOLANT AS PART OF SCHEDULED DIESEL ENGINE MAINTENANCE. THIS STEP IS ESPECIALLY CRITICAL FOR VEHICLES UTILIZED UNDER SEVERE SERVICE SPECIAL OPERATING CONDITIONS (TOWING, LONG IDLE/COMMERCIAL DELIVERY, OFF ROAD/DUSTY, BIODIESEL) IN ORDER TO AVOID ENGINE FAILURES. USE THE ROTUNDA 3-WAY ANTIFREEZE TEST STRIP KIT (#328-00001) TO CHECK NITRITE LEVELS OF THE ENGINE COOLANT. THIS NEW PRODUCT OFFERED BY ROTUNDA INCLUDES 1 BOTTLE (50 TEST STRIPS) OF 3-WAY HD ANTIFREEZE COOLANT DIAGNOSTIC TESTS AND A SAMPLING KIT WITH VIAL AND SYRINGE. KIT COST IS $28.99 AND CAN BE PURCHASED ONLINE AT www.FORDROTUNDA.COM (SEARCH PRODUCT NUMBER 328-00001) OR BY PHONE AT 1-800-ROTUNDA (768-8632), OPTION 2.
2159 - 2008-2009 F-SUPER DUTY - 6.4L - P0401/P0402/P2002/P244A/P2453/P2455 AND/OR DPF DAMAGE CAUSED BY AFTERMARKET EQUIPMENT
SOME 2008-2009 6.4L DIESEL VEHICLES MAY SET DTC P0401,P0402,P2002,P244A, P2453, P2455 OR HAVE A DAMAGED DPF/DOC (BLACK SOOT IN TAIL PIPE, BLACK OR WHITE SMOKE) RESULTING FROM AFTERMARKET MODIFICATIONS. BEFORE PROCEEDING WITH NORMAL DIAGNOSTICS, INSPECT THE VEHICLE FOR NON-APPROVED AFTERMARKET AIR INDUCTION SYSTEMS, AND OR AFTER DOC/DPF EXHAUST SYSTEMS OR ELIMINATION OF THE DOC/DPF AND OR PERFORMANCE ENHANCING PROGRAMS. THE USE OF NON APPROVED AFTERMARKET AIR INDUCTION SYSTEMS CAN ALSO CONTAMINATE THE MAF SENSOR, AND CAUSE INACCURATE EGR OPERATION AND FALSE DIAGNOSTICS CODES. REPLACEMENT OF FACTORY COMPONENTS WILL NOT RESOLVE THESE CONCERNS, AND SHOULD NOT BE ATTEMPTED OR COVERED UNDER WARRANTY. PLEASE REFER TO THE WARRANTY AND POLICY MANUAL, SECTION 3, FOR WARRANTY IMPLICATIONS OF REPAIRS RELATED TO VEHICLE MODIFICATIONS.
2149 - F-SUPER DUTY 5.4L AND 6.8L GAS ENGINE CALIBRATION UPDATE
SEE TSB 09-07-12 FOR DETAIL 09-07-12
2148 - 6.0L DIESEL CALIBRATION UPDATE
SEE TSB 09-07-11 FOR DETAIL 09-07-11
2147 - DIAGNOSTIC PROCEDURE FOR TRAILER TOW LIGHTS - SERVICE TIP
SEE TSB 09-07-10 FOR DETAIL 09-07-10
2145 - SYNC SOFTWARE UPDATE - VARIOUS ISSUES
SEE TSB 09-07-09 FOR DETAIL 09-07-09
2122 - F650/F750 VEHICLE LEAN CORRECTION PROCEDURE
SEE TSB 09-06-10 FOR DETAIL 09-06-10
2118 - MULTIPLE VEHICLES - BRAKE PEDAL LOW TRAVEL AFTER BRAKE BOOSTER, MASTER CYLINDER OR PEDAL REPAIRS
FOLLOWING BRAKE BOOSTER, MASTER CYLINDER OR BRAKE PEDAL REPAIRS, IF THE VEHICLE EXHIBITS A LOW BRAKE PEDAL OR BRAKE PEDAL WITH REDUCED TRAVEL, CHECK THE STOPLAMP AND/OR SPEED CONTROL DEACTIVATION (IF EQUIPPED) SWITCH(ES) FOR IMPROPER REMOVAL/INSTALLATION THAT MAY RESULT IN IMPROPER BRAKE PEDAL RETURN. FAILURE TO PROPERLY REMOVE/INSTALL THE SWITCH(ES) PER THE WORKSHOP MANUAL (WSM) PROCEDURES CAN CAUSE THESE PEDAL CONCERNS AND MAY PREVENT THE BRAKE PEDAL FROM RETURNING TO THE FULL REST POSITION. WSM SECTIONS 206-06/07 AND 417-01 MUST BE FOLLOWED TO PREVENT DAMAGE TO THE STOPLAMP AND/OR SPEED CONTROL DEACTIVATION SWITCH(ES) AND THE ASSOCIATED BRAKE PEDAL CONCERNS. VERIFY PROPER BRAKE OPERATION AFTER PERFORMING ANY REPAIR(S).
2110 - 2008-2009 F-SUPER DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES CODE P123C
SOME 2008-2009 F250-550 SUPER-DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES MAY EXHIBIT DIAGNOSTIC TROUBLE CODE(DTC) P123C(COLD START TURBO PROTECTION- FORCED LIMITED POWER). THIS NON-MIL DTC WILL BE STORED IN THE POWERTRAIN CONTROL MODULE (PCM) WHEN THE ENGINE OIL TEMPERATURE(EOT), ENGINE COOLANT TEMPERATURE(ECT) AND INTAKE AIR TEMPERATURE(IAT) ARE BELOW -15F (-26C) AT START UP AND ENGINE BLOCK HEATER IS NOT UTILIZED. DTC P123C WILL ALSO BE ACCOMPANIED BY LIMITED THROTTLE INPUT FOR 30 SECONDS AFTER ENGINE START UP AND A MESSAGE IN THE INSTRUMENT CLUSTER MESSAGE CENTER WILL READ "ENGINE WARMING PLEASE WAIT XX" A TIMER WILL THEN BEGIN A COUNTDOWN FROM 30 SECONDS, THEN "OK TO DRIVE" WILL DISPLAY ONCE THE COUNTER HAS REACHED 0 (ZERO). IF NORMAL PCED DIAGNOSTICS DO NOT LEAD TO A CONCERN, CLEAR DTC AND RETURN VEHICLE TO CUSTOMER.
2109 - SOME 2008-2009 F-SUPER-DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES WITH EGT SENSOR AND/OR EGT CIRCUIT FAULT DIAGNOSTIC TROUBLE CODES(DTCS)
SOME 2008-2009 F-SUPER-DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES MAY EXHIBIT EXHAUST GAS TEMPERATURE (EGT) SENSOR AND/OR EGT CIRCUIT FAULT DIAGNOSTIC TROUBLE CODES(DTCS). EGT CIRCUIT DIAGNOSTIC TROUBLE CODES MUST BE DIAGNOSED FOR POSSIBLE INTERMITTENT CONCERNS BEFORE DISCONNECTING ANY IN LINE CONNECTOR OR SENSOR. DISCONNECTING SENSORS OR CONNECTORS MAY DISTURB INTERMITTENT HARNESS CONCERNS RESULTING IN MISDIAGNOSIS OF EGT SENSORS. EGT SENSOR CIRCUIT, EGT11, EGT12, OR EGT13, MUST BE IDENTIFIED THROUGH SELF-TEST DTC CODES. PLEASE REFERENCE IMPROVED EXHAUST GAS TEMPERATURE (EGT) SENSOR DIAGNOSTIC ROUTINES IN PCED PIN POINT TEST RC.
2103 - 2008-2009 F-SUPER DUTY 6.4L AIR INDUCTION SYSTEM RESTRICTION - SNOW - BUILT ON OR BEFORE 3/16/2009
SEE TSB 09-06-08 FOR DETAIL 09-06-08
2100 - 2008-2009 F-SUPER DUTY SPEAKER POP NOISE
SOME 2008-2009 F-SUPER DUTY VEHICLES EQUIPPED WITH A STANDARD SINGLE CD RADIO (NON-PREMIUM) MAY EXHIBIT A SPEAKER POP NOISE. THIS TYPICALLY HAPPENS AFTER AN EXTENDED DRIVE PERIOD WHEN VEHICLE IS WARM AND OPENING/CLOSING A DOOR; HOWEVER, IT MAY HAPPEN ANYTIME THE RADIO IS TURNED OFF. USING THE VEHICLE HEATER THROUGH THE IP PANEL VENTS (ON HIGH SETTING) MAY ALSO CAUSE THE CONDITION TO REPEAT MORE OFTEN. VERIFY THAT THE HEATER AND INSTRUMENT PANEL DUCTS ARE NOT MIS-ALIGNED (BEHIND THE RADIO). IF NECESSARY, SECURE DUCTS SO THE HEAT IS NOT RELEASED TO THE BACK OF THE RADIO. IF THIS PROCEDURE DOES NOT RESOLVE THE SPEAKER POP CONCERN, DO NOT REPLACE THE RADIO, AND DO NOT ATTEMPT FURTHER REPAIRS. ENGINEERING IS CURRENTLY INVESTIGATING NEW RADIO SOFTWARE. MONITOR OASIS FOR UPDATES.
2095 - THE NEW IDS 'EVAP TEST' TOOL REQUIRES TECHNICIANS TO ENTER THE VEHICLE'S FUEL TANK SIZE
THIS INFORMATION IS LOCATED IN THE MAINTENANCE & SPECIFICATIONS SECTION OF THE OF THE VEHICLE'S OWNER GUIDE. TO VIEW THE OWNER GUIDE ON PTS, INFORD OR THE MEXICO TECHNICIAN WEBSITES 1) SELECT 'SERVICE PUBLICATIONS' 2) SELECT THE 'OTHER' TAB 3) SELECT 'OWNER INFORMATION'
2087 - DIESEL LOWER CRANKCASE SEAL UPDATED SERVICE PROCEDURE
THE WORKSHOP MANUAL PROCEDURES FOR 4.5L/6.0L/6.4L DIESEL ENGINE EQUIPPED VEHICLES FOR REMOVAL AND INSTALLATION OF THE LOWER CRANKCASE SEAL HAVE BEEN UPDATED TO INCLUDE NEW INSTRUCTIONS FOR THE PROPER INSTALLATION OF A THIN FILM OF MOTORCRAFT GASKET MAKER (TA-16) TO THE UPPER AND LOWER CRANKCASE GROOVES OF THE BLOCK AND BEDPLATE PRIOR TO INSTALLING THE CRANKCASE SEAL. REFER TO THE ON-LINE WORKSHOP MANUAL SECTION 303-01C FOR THE REVISED PROCEDURES.
2056 - DIESEL REAR SEAL UPDATED SERVICE PROCEDURE
SOME 4.5L/6.0L/6.4L DIESEL ENGINE EQUIPPED VEHICLES MAY REQUIRE REAR CRANKSHAFT SEAL REPLACEMENT. THE WORKSHOP MANUAL PROCEDURES FOR REMOVAL AND INSTALLATION OF THE REAR CRANKSHAFT SEAL AND WEAR RING HAVE BEEN UPDATED TO INCLUDE NEW INSTRUCTIONS FOR THE PROPER REMOVAL AND INSTALLATION OF A REDESIGNED REAR SEAL, INCLUDING THE PLASTIC STEP UP TOOL.REFER TO THE ON-LINE WORKSHOP MANUAL SECTION 303-01C FOR THE REVISED PROCEDURES.
1971 - SERVICE TIP - CONFIGURING/PROGRAMMING 2009 VEHICLES EQUIPPED WITH NEXT GENERATION NAVIGATION RADIOS (NGN)
SOME 2009 MODEL YEAR VEHICLES EQUIPPED WITH NEXT GENERATION NAVIGATION RADIO MAY FAIL TO CONFIGURE/PROGRAM WHEN USING THE IDS TOOL TO PROGRAM THE NAVIGATION SYSTEM. IF THIS OCCURS DO NOT REPLACE NAVIGATION RADIO. THIS MAY BE DUE TO A NORMAL COMMUNICATION DELAY BETWEEN THE IDS TOOL AND THE NAVIGATION SYSTEM. TO PREVENT THIS ISSUE IN THE FUTURE, MAKE SURE THE VEHICLE'S IGNITION SWITCH IS IN THE RUN POSITION FOR APPROXIMATELY 1 MINUTE PRIOR TO USING THE TOOL CONFIGURE/PROGRAM THE NAVIGATION SYSTEM. (NOTE: BATTERY LEVEL OF CHARGE IS EXTREMELY IMPORTANT, IT'S HIGHLY RECOMMENDED TO USE A BATTERY CHARGER OR RUNNING THE ENGINE DURING THIS PROCEDURE. NOT FOLLOWING THIS STEP, CAN RESULT IN A FAILED RADIO.)
1970 - 1999-2009 MULTIPLE VEHICLES - DIESEL ENGINE FUEL CONDITIONER
SOME 1999-2009 F-SUPER DUTY, E-SERIES, EXCURSION, F650/750, AND LCF VEHICLES EQUIPPED WITH A DIESEL ENGINE MAY EXHIBIT LOW POWER, POOR FUEL ECONOMY, FUEL GELLING IN COLD WEATHER (A HIGHER OCCURRENCE OF FUEL GELLING MAY OCCUR WITH THE USE OF BIO-DIESEL BLENDED FUELS), EXCESSIVE WHITE SMOKE ON COLD START, HARD START, OR COKING OF COMPONENTS EXPOSED TO EXHAUST. THESE CONDITIONS MAY BE DUE TO POOR FUEL QUALITY. IF NO ROOT CAUSE IS FOUND DURING NORMAL DIAGNOSTICS, ADVISE THE CUSTOMER TO USE A DIFFERENT BRAND OF FUEL. USE OF A NON ALCOHOL ADDITIVE CAN IMPROVE CETANE LEVELS, SUCH AS "DIESEL CETANE BOOST AND PERFORMANCE IMPROVER" MOTORCRAFT PM-22-A (PM-22-B CAN). COLD FLOW PERFORMANCE CAN BE IMPROVED WITH "DIESEL FUEL ANTI-GEL AND PERFORMANCE IMPROVER" MOTORCRAFT PM-23-A (PM-23-B CAN).
1968 - 2008-2009 F-SUPER DUTY 5.4L AND 6.8L - 5R110 TRANSMISSION REVERSE ENGAGEMENT PROTECTION STRATEGY
2008-2009 F-SUPER DUTY 5.4L AND 6.8L APPLICATIONS EQUIPPED WITH A 5R110W AUTOMATIC TRANSMISSION ARE EQUIPPED WITH A TRANSMISSION PROTECTION STRATEGY THAT MAY CAUSE SOME CUSTOMERS TO EXPERIENCE SYMPTOMS OF; INTERMITTENT DELAYED REVERSE ENGAGEMENT, NEUTRALING OUT IN REVERSE, OR LOSS OF ENGINE POWER IN REVERSE, WHEN PERFORMING REPETITIVE ENGAGEMENTS AND DRIVE-AWAY EVENTS SUCH AS DURING SNOWPLOWING. THIS TRANSMISSION PROTECTION STRATEGY CAN PLACE THE TRANSMISSION IN A NEUTRAL STATE AFTER CERTAIN CRITERIA (VEHICLE AND ENGINE SPEED LIMITERS) ARE MET WHILE REVERSE GEAR IS SELECTED. USAGE IN 4X4 LOW RANGE CAN ALLOW THE ENGINE SPEED LIMITER (3400-3750 RPM) TO BE REACHED MORE EASILY. ALLOWING THE VEHICLE TO COME TO A "COMPLETE" STOP BEFORE SELECTING REVERSE CAN REDUCE ACTIVATION OF THE SPEED LIMITER STRATEGY.
1965 - VEHICLES EQUIPED WITH TRANSFER CASE SLIP YOLKS
MAY EXPERIENCE A SMALL AMOUNT OF FLUID LEAKAGE (DROPLETS) IN THE SLIP YOLK AREA OF THE TRANSFER CASE. THE LEAKAGE IS THE RESULT OF MINOR FLUID SEAPAGE AS THE SHIPPING CAP IS REMOVED DURING ASSEMBLY. IF YOU ENCOUNTER THIS CONDITION, VERY CAREFULLY WIPE OFF THE SLIP YOLK AREA AND INSPECT THE SEAL/YOLK INTERFACE FOR FOR OBVIOUS DAMAGE. TEST DRIVE THE VEHICLE TO MAKE SURE NO LEAKS ARE PRESENT.
1964 - 2008 SYNC EQUIPPED VEHICLES - APPLE IPOD OR IPHONE TURNS OFF AFTER 30-60 SECONDS
SEE TSB 09-03-08 FOR DETAIL 09-03-08
1963 - 2005-2009 F-SUPER DUTY - 18" CONTI TR ALL-TERRAIN TIRES
THE 18" CONTI TR TIRES MEET ALL FORD STANDARDS FOR ALL-TERRAIN TIRES: SOME CUSTOMERS MAY PERCEIVE THE OPTIONAL 18" CONTI TR TIRES, AVAILABLE ON THE 2005-2009 F-SUPER DUTY, AS NOT BEING ALL-TERRAIN TIRES. THE 18" CONTI TR TIRES MEET ALL FORD STANDARDS FOR ALL-TERRAIN TIRES. THESE INCLUDE, BUT ARE NOT LIMITED TO, 4X4 DURABILITY STANDARDS WHICH INCLUDES ASPECTS OF SAND, GRAVEL, HILL CLIMB, ROCK, AND STRUCTURAL DURABILITY EVENTS. ADDITIONALLY, THE TIRES MEET RIGOROUS LAB DURABILITY REQUIREMENTS AND ON-VEHICLE PERFORMANCE REQUIREMENTS.
1946 - 2008-2009 F-SUPER DUTY - 6.4L DIESEL LACKS POWER TOWING
SOME 2008-2009 SUPER DUTY 6.4L DIESEL UNITS MAY EXHIBIT A LACK OF POWER CONCERN WITHOUT A DTC DUE TO ECM DERATE STRATEGIES DESIGNED FOR ENGINE TEMPERATURE PROTECTION. THE FOLLOWING TEMPERATURE INPUTS (PIDS) CAN BE MONITORED WITH THE INTEGRATED DIAGNOSTIC SYSTEM (IDS) SCAN TOOL. ENGINE DERATE W/O DTC OCCURS WHEN ANY OF THE CONDITIONS EXIST; EGR INLET TEMPERATURE (EGRT_A) EXCEEDS 1300F (705C), FUEL TEMPERATURE (FRT) EXCEEDS 194F (90C), ENGINE COOLANT TEMPERATURE (ECT) EXCEEDS 235F (113C), OR WHEN ENGINE OIL TEMPERATURE (EOT) EXCEEDS 259F (126C). VEHICLES THAT HAVE BEEN UPDATED WITH IDS SERVICE CALIBRATION LEVEL 58.4 OR LATER WILL DISPLAY THE REDUCED ENGINE POWER MESSAGE AND HIGH TEMPERATURE GAUGE READING WHEN HIGH EOT CONDITIONS ARE ENCOUNTERED. VERIFY COOLING SYSTEM, OIL COOLER AND EOT SENSOR OPERATION FOR HIGH EOT CONCERNS.
1893 - 2008-2009 MULTIPLE VEHICLES - HEADLAMP ADJUSTMENT - CHASSIS CAB INCOMPLETE VEHICLES
2008-2009 E-SERIES, F-SUPER DUTY, F-650/750 AND LCF CHASSIS CAB VEHICLES HEADLAMP INITIAL AIM IS SET AT THE ASSEMBLY PLANT, BUT MAY NOT BE CORRECT FOR THE FINAL STAGE MANUFACTURER'S FINAL VEHICLE CONFIGURATION. THEREFORE, HEADLAMP AIM VERIFICATION IS THE RESPONSIBILITY OF THE FINAL STAGE MANUFACTURER, WHICH SHOULD BE PART OF THE COMPLETED VEHICLE SIGN-OFF. HEADLAMP AIM SHOULD BE CHECKED AND ADJUSTED AS NECESSARY, PER OWNER'S GUIDE INSTRUCTIONS AND/OR RESPECTIVE WORKSHOP MANUAL ON THE COMPLETED VEHICLE BY THE FINAL STAGE MANUFACTURER.
1891 - 2004-2009 F-650/750 - IF BODY BUILDER INSTALLS LIGHT EMITTING DIODE (LED) LAMPS, REPLACE THE FACTORY INSTALLED FLASHER WITH A YC3Z-13350-AA
MOST 2004-2009 F-650/750 VEHICLES ARE PRODUCED WITH STANDARD TURN SIGNAL BULBS. IF A BODY BUILDER INSTALLS LIGHT EMITTING DIODE (LED) LAMPS, THE TURN SIGNALS MAY FLASH RAPIDLY WHEN TURNED ON. TO SERVICE, REPLACE THE FACTORY INSTALLED FLASHER WITH A YC3Z-13350-AA FLASHER. THIS MODIFICATION IS NOT COVERED BY WARRANTY, BUT WILL RESOLVE THE CONCERN.
1877 - COOLANT LOSS - 6.0L TSB 08-11-3 CORRECTION/UPDATE
WHEN PERFORMING TSB 08-11-3 STEPS 5 AND 6, FOR MONITORING EOT VS. ECT, PLEASE USE THE REVISED SPECIFICATION OF A MAXIMUM DIFFERENCE OF 15 DEGREES DURING THE TEST. IT IS IMPORTANT TO COMPLETE ALL STEPS IN THE ORDER AS OUTLINED. IF STEPS 5 AND 6 ARE PERFORMED PRIOR TO BEING DIRECTED TO DO SO, THE TEST RESULTS WILL BE NEGATIVELY AFFECTED AND MAY LEAD TO AN IMPROPER DIAGNOSIS. TSB 08-11-3 IS IN PROCESS OF BEING UPDATED. MONITOR OASIS FOR UPDATES.
1876 - 2008-2009 F-SUPER DUTY 6.4L DIESEL - NO CRANK CONDITION DUE TO EGT SENSOR OR BATTERY DISCONNECT
SOME 2008-2009MY F250-550 SUPER-DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES MAY EXHIBIT A NO CRANK CONDITION FOR (1) HOUR WHEN OPEN OR INTERMITTENT CIRCUIT FAULTS ARE PRESENT OR WHEN EXHAUST GAS TEMPERATURE(EGT) SENSORS ARE DISCONNECTED DURING PCED PIN POINT TEST RC 4 KOEO CIRCUIT DIAGNOSTIC ROUTINES. IF THE VEHICLE IS A NO-CRANK AND EXHAUST GAS TEMPERATURE(EGT) SENSOR DIAGNOSTIC TROUBLE CODES(DTCS) ARE PRESENT DO NOT DISCONNECT VEHICLE BATTERIES FOR AT LEAST (1) HOUR. DISCONNECTING VEHICLE BATTERIES WILL NOT ERASE DTCS. DO NOT REPLACE THE POWERTRAIN CONTROL MODULE(PCM) FOR THESE CONCERNS. CONTINUE WITH NORMAL DIAGNOSTICS WHEN (1) HOUR FAILURE MODE EFFECTS MANAGEMENT(FMEM) TIMER COUNT DOWN HAS COMPLETED. THIS CONCERN IS UNDER INVESTIGATION. MONITOR OASIS FOR UPDATES
1875 - 2005 EXCURSION / 2005-2009 F-SUPER DUTY, ECONOLINE - 5.4L/6.8L - CORRECT PROCEDURE FOR CHECKING EVAP SYSTEM LEAKS ON 40 GALLON FUEL TANKS
WHEN CHECKING FOR EVAP SYSTEM LEAKS ON 2005-2009 F-SUPER DUTY, 2005-2009 ECONOLINE OR 2005 EXCURSION VEHICLES EQUIPPED WITH FUEL TANKS 40 GALLONS AND LARGER, IT IS RECOMMENDED TO RUN THE VEHICLE'S ON BOARD EVAP MONITOR TEST WITHIN THE OBDII DRIVE CYCLE TEST. IT IS NOT RECOMMENDED TO PERFORM THE IDS/SCAN TOOL EVAP TEST ON VEHICLES WITH 40 GALLON AND LARGER FUEL TANKS, THIS MAY RETURN ERRONEOUS/INACCURATE RESULTS.
1867 - 2008-2009 E-SERIES AND F-250/F-350 - STEERING GEAR LEAK
2008-2009 E-SERIES AND F-250/F-350 IF WORKSHOP MANUAL DIAGNOSTICS LEAD TO A LEAK AT THE STEERING GEAR, INSPECT THE STEERING GEAR AND DETERMINE THE SOURCE OF THE LEAK. IF THE LEAK IS RELATED TO SEALS, O-RINGS AND/OR THE SECTOR SHAFT COVER, RESEAL THE STEERING GEAR USING GEAR RESEAL KIT (E-SERIES 3C2Z-3E502-A F-250/F-350 3C3Z-3E502-A). REFER TO DISASSEMBLY AND ASSEMBLY IN SECTION 211-02. IF THERE IS DAMAGE OR LEAKAGE FROM THE STEERING GEAR HOUSING OR MATING COMPONENTS, A NEW STEERING GEAR MUST BE INSTALLED. REFER TO SECTION 211-02. NOTE: THERE IS NO SEAL KIT FOR F-450 OR F-550 AND SEAL KIT (3C3Z-3E502-A) CAN ONLY BE USED ON F-250 AND F-350.
1843 - 2004-2009 E-SERIES/2003-2005 EXCURSION/2003-2007 F-SUPER DUTY - 6.0L TURBO UNISON RING AVAILABLE FOR SERVICE
A 6.0L TURBOCHARGER UNISON RING IS NOW AVAILABLE SEPARATELY. THIS PART MAY BE NEEDED WHEN PERFORMING TSB 08-16-13, '6.0L TURBOCHARGER CARBON DEPOSIT DIAGNOSTICS AND SERVICE TIPS', STEP 9 OF THE INSPECTION PROCEDURE. THE UNISON RING, PART # 3C3Z-6C885-A, MAY BE USED IN CONJUNCTION WITH THE TURBO CLEANING OPERATION WHEN NECESSARY AND CAN BE ORDERED THROUGH YOUR POWERTRAIN DISTRIBUTOR. TSB 08-16-13 IS PLANNED TO BE UPDATED IN THE FIRST QUARTER OF 2009 AND WILL CONTAIN THIS ADDITIONAL INFORMATION.
1731 - 2008 - 2009 F-SUPER DUTY - 6.4L DIESEL COOLANT FILL
6.4L DI WITH TWO VENT PORT DEGAS BOTTLE COOLANT FILL (WSM RADKITPLUS PROCEDURE RECOMMENDED). WSM FILL AND BLEED WITHOUT RADKITPLUS PROCEDURE BEING UPDATED TO: 1)WITH ENGINE OFF, FILL DEGAS BOTTLE TO BOTTOM OF FILLER NECK. 2)START ENGINE AND IDLE FOR 2 MINUTES. 3)REFILL TO THE BOTTOM OF FILLER NECK. 4)RUN ENGINE AT 2000 RPM FOR 5 MINUTES. 5)REFILL TO BOTTOM OF FILLER NECK. 6)INSTALL DEGAS BOTTLE CAP. NOTE, DRIVING VEHICLE FOR APPROX 5 MILES SHOULD DROP COOLANT TO PROPER LEVEL IN DEGAS BOTTLE. WSM COOLANT LEVEL CHECK BEING UPDATED TO:1)COOL ENGINE COOLANT LEVEL SHOULD BE WITHIN COLD FILL RANGE OF DEGAS BOTTLE. 2)WARMED ENGINE AS INDICATED BY THE TEMPERATURE GAUGE READING IN MIDDLE OF NORMAL RANGE, COOLANT LEVEL SHOULD BE 10-20MM ABOVE TOP OF COLD FILL RANGE IF DEGAS CAP IS INSTALLED AND 20 30MM ABOVE TOP OF COLD FILL RANGE IF DEGAS CAP IS REMOVED.
This topic is now closed to further replies.
