fs1022 fuel separator
dermo1
Have just installed a new fs1022 on a cummins powerd monaco coach old fs1022 had a square wif sensor plug.New fs1022 has a ovel plug installed new pig tail now has a code 428 for wif sensor. tested sensors old one about 85ohms resistance and if it is jumperd in code goes away. any one else had this problem is thare a fix
Was there a code before replacing the filter, or did it start after?
FAULT CODE 428
Water-In-Fuel Sensor Circuit - Voltage Above Normal or Shorted to High Source
Printable Version
Overview
CODE REASON EFFECT
Fault Code : 428
PID: P097
SPN: 97
FMI: 3/3
LAMP: Amber
SRT:
Water-in-Fuel Sensor Circuit - Voltage Above Normal or Shorted to High Source. High voltage detected at the water-in-fuel circuit.
None on performance. No water-in-fuel warning available.
SMALL | MEDIUM | LARGE
Circuit Description
The water-in-fuel sensor is attached to the suction-side fuel filter. The water-in-fuel sensor sends a signal to the Electronic Control Module (ECM) when a set volume of water has accumulated in the fuel filter. The water-in-fuel circuit contains two wires: a return and a signal wire.
Component Location
The water-in-fuel sensor is integrated into the bottom of the Original Equipment Manufacturer (OEM) supplied fuel filter. Refer to the OEM troubleshooting and repair manual for location.
Shop Talk
Beginning with Engine Serial Number (ESN)14039654, the temperature sensor return circuit was separated from the pressure sensor return circuit. For ESNs prior to this and with engine wiring harness Part Number 3682854, refer to the Common Pressure/Temperature Sensor Return Circuit above. For this ESN and greater or for any other engine wiring harness part number, refer to the Separate Pressure/Temperature Sensor Return Circuit above.
The water-in-fuel sensor shares return wires in the engine harness with other sensors. An open return can cause multiple fault code s to be active. Before troubleshooting Fault Code 428 , check for multiple fault code s.
Possible causes for this fault code include:
Open return or signal circuit in the harness, connectors, sensor, or ECM.
Signal wire shorted to sensor supply or battery voltage.
Cautions and Warnings
CAUTION
To reduce the possibility of damaging a new ECM, all other active fault code s must be investigated prior to replacing the ECM.
CAUTION
To reduce the possibility of pin and harness damage, use the following test lead when taking a measurement:
Part Number 3822758 - male Deutsch/AMP/Metri-Pack test lead
Part Number 3822917 - female Deutsch/AMP/Metri-Pack test lead
Part Number 3823993 - 16 AWG male Deutsch test lead
Part Number 3823994 - 16 AWG female Deutsch test lead.
Troubleshooting Steps
STEPS SPECIFICATIONS
STEP 1. Check the fault code s.
STEP 1A. Check for an inactive fault code . Fault Code 428 inactive?
STEP 2. Check the water-in-fuel sensor and circuit.
STEP 2A. Inspect the water-in-fuel sensor and connector pins. Dirty or damaged pins?
STEP 2B. Check the sensor resistance. Greater than 100k ohms?
STEP 2C. Check the fault code s and verify sensor condition. Fault Code 428 active?
STEP 3. Check the ECM and engine harness.
STEP 3A. Inspect the ECM and engine harness connector pins. Dirty or damaged pins?
STEP 3B. Check the ECM response. Fault Code 429 active and Fault Code 428 inactive?
STEP 3C. Check for an open circuit in the engine harness. Less than 10 ohms?
STEP 3C-1. Check for an open circuit in the engine harness.
STEP 3D. Check for a pin-to-pin short circuit in the engine harness. Greater than 100k ohms?
STEP 3E. Check for an inactive fault code . Fault Code 428 inactive?
STEP 4. Clear the fault code s:
STEP 4A. Disable the fault code . Fault Code 428 inactive?
STEP 4B. Clear the inactive fault code s. All fault code s cleared?
Guided Step 1 - Check the fault code s.
Guided Step 1A - Check for an inactive fault code .
Conditions
Turn keyswitch ON.
Connect INSITE™ electronic service tool.
Action
Use INSITE™ to read the fault code s.
YES NO
No Repair No Repair
Inactive or Intermittent Fault Code , Procedure 019-362
Go to 2A
Guided Step 2 - Check the water-in-fuel sensor and circuit.
Guided Step 2A - Inspect the water-in-fuel sensor and connector pins.
Conditions
Turn keyswitch OFF.
Disconnect the water-in-fuel sensor from the sensor extension harness.
Action
Corroded pins
Bent or broken pins
Pushed back or expanded pins
Moisture in or on the connector
Missing or damaged connector seals
Dirt or debris in or on the connector pins.
Connector shell shroud broken
Damaged connector locking tab
Damaged wire or engine harness insulation.
For general inspection techniques, refer to Component Connector and Pin Inspection, Procedure 019-361.
YES NO
A defective connection has been detected in the sensor or harness connector.
Clean the connector and pins.
Repair the damaged harness, connector, or pins if possible.
Refer to Procedure 019-043.
No Repair
Go to 4A
Go to 2B
Guided Step 2B - Check the sensor resistance.
Conditions
Turn keyswitch OFF.
Action
Measure the resistance between the water-in-fuel SIGNAL pin and the water-in-fuel RETURN pin at the water-in-fuel sensor connector.
Refer to the wiring diagram for connector pin identification.
For general resistance measurement techniques, refer to Resistance Measurements Using a Multimeter and Wiring Diagram, Procedure 019-360.
YES NO
Replace the water-in-fuel sensor.
Refer to Procedure 019-127.
No Repair
Go to 4A
Go to 2C
Guided Step 2C - Check the fault code s and verify sensor condition.
Conditions
Turn keyswitch OFF.
Connect the water-in-fuel sensor to the sensor extension harness.
Turn keyswitch ON.
Action
YES NO
No Repair
None. The removal and installation of the connector corrected the failure.
Go to 3A
Go to 4A
Guided Step 3 - Check the ECM and engine harness.
Guided Step 3A - Inspect the ECM and engine harness connector pins.
Conditions
Turn keyswitch OFF.
Disconnect the engine harness from the ECM.
Action
Corroded pins
Bent or broken pins
YES NO
A defective connection has been detected in the ECM connector or engine harness connector.
No Repair
Go to 4A
Go to 3B
Guided Step 3B - Check the ECM response.
Conditions
Turn keyswitch OFF.
Turn keyswitch ON.
Action
Check for the appropriate circuit response after 30 seconds.
YES NO
No Repair
Call for pre-authorization.
Replace the ECM.
Refer to Procedure 019-031.
Go to 3C
Go to 4A
Guided Step 3C - Check for an open circuit in the engine harness.
Conditions
Turn keyswitch OFF.
Action
Measure the resistance between the engine harness ECM connector water-in-fuel sensor RETURN pin and the extension harness water-in-fuel sensor connector RETURN pin.
For general resistance measurement techniques, refer to the Resistance Measurements Using a Multimeter and Wiring Diagram, Procedure 019-360.
Less than 10 ohms?
Less than 10 ohms?
YES NO
No Repair
An open return circuit has been detected in the engine harness or sensor extension harness.
Repair or replace the engine harness or sensor extension harness.
Go to 3C-1
Go to 4A
Guided Step 3C-1 - Check for an open circuit in the engine harness.
Conditions
Turn keyswitch OFF.
Action
Measure the resistance between the engine harness ECM connector water-in-fuel sensor SIGNAL pin and the extension harness water-in-fuel sensor connector SIGNAL pin.
Less than 10 ohms?
Less than 10 ohms?
YES NO
No Repair
An open signal circuit has been detected in the engine harness or sensor extension harness.
Go to 3D
Go to 4A
Guided Step 3D - Check for a pin-to-pin short circuit in the engine harness.
Conditions
Turn keyswitch OFF.
Action
Measure the resistance between the water-in-fuel SIGNAL pin in the engine harness ECM connector and all other pins in the engine harness ECM connector.
YES NO
No Repair
A pin-to-pin short circuit on the signal line has been detected in the engine harness or sensor extension harness.
Go to 3E
Go to 4A
Guided Step 3E - Check for an inactive fault code .
Conditions
Connect all components.
Turn keyswitch ON.
Action
YES NO
Troubleshooting procedures need to be repeated from the beginning. A failure mode should have been detected.
Go to 4A
Go to 1A
Guided Step 4 - Clear the fault code s.
Guided Step 4A - Disable the fault code .
Conditions
Action
Start the engine and let it idle for 1 minute.
Use INSITE™ to verify the fault code is inactive.
YES NO
No Repair
Return to troubleshooting steps or contact a local Cummins Authorized Repair Location if all steps have been completed and rechecked.
Go to 4B
Go to 1A
Guided Step 4B - Clear the inactive fault code s.
Conditions
Turn keyswitch ON.
Action
Use INSITE™ to erase the inactive fault code s.
YES NO
No Repair
Troubleshoot any remaining active fault code s.
Repair complete
Appropriate troubleshooting steps
First of all, I don't know squat about a Cummins, but I can make a suggestion on the diag. Does the new sensor also read 85 ohms? Check voltage at both sides of the sensor with it installed and the key on. You should have 5v or 12v VREF on one pin and a return voltage on the other pin. Check and make sure your return voltages are the same. If they are not, change the resistance by adding a resistor in series or parallel with the two pins. In series with the circuit will increase the resistance and lower the return voltage, in parallel across the pins will raise the return voltage. Buy a multi-pack of resistors at Radio Shack. A lifetime worth of resistors (50-100 resistors ranging from 10 ohms to 10 megaohms) for this kind of stuff will set you back $1-3.
found the anser talking to fleetguard. about 2 years ago fs1022 seperator was updated with the new ovel shaped wif sensor. to get the old square sensor u wave to use a fs1003 fixes the problem. the wif sensors dont interchange the resistance in the sensors is differnt . thanks for all the help.
