eastendpowerstroke Posted November 28, 2007 Share Posted November 28, 2007 OK I have a 88 f-250 with many problem in my bay the one I need help with is at some time in the past somebody disconnected the hose from the fuel filter to the #1 injector return and capped it at the filter housing, and replaced the return cap with a single fitting. I'm replacing the orings because there leaking fuel should I return the hose to it's original routing or leave the Gennie in the bottle and leave it alone??? (Don't ask, Don't tell). It runs real good other wise Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 28, 2007 Share Posted November 28, 2007 I would get the proper #1 return collar and replace the hose. If the air bleed wasn't necessary it wouldn't be there, right? /forums/images/%%GRAEMLIN_URL%%/2cents.gif Quote Link to comment Share on other sites More sharing options...
OHNO60 Posted November 29, 2007 Share Posted November 29, 2007 HOLY COW! THERE STILL AROUND? Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted November 29, 2007 Author Share Posted November 29, 2007 OHNO60 said: HOLY COW! THERE STILL AROUND?Yeah cool huh /forums/images/%%GRAEMLIN_URL%%/rolleyes.gif Keith, the 90 degree 3/16 cap is D99 from ford so I just left well enough alone and fixed the leaks at the rest of the injectors. Quote Link to comment Share on other sites More sharing options...
Mekanik Posted November 30, 2007 Share Posted November 30, 2007 They did something goofy to the shrader valve too. Maybe it was leaking and they put that hose on the end to keep the fuel from leaking out. /forums/images/%%GRAEMLIN_URL%%/scratchhead.gif Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 30, 2007 Share Posted November 30, 2007 I recall these engines always being sensitive to leaks. If it wasn't the return collars it was the hoses connecting them rotting out. I went round and round over that with more than one truck back in the day. The rubber crush seals in the fittings were a real pain in the ass too because they might not leak fuel but they can allow air into the system after shut down and cause hard starting problems by making the injection pump lose prime. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted November 30, 2007 Share Posted November 30, 2007 Found this site for a parts kits for these. http://www.mwfi.com/dieselPage/ford_73.htm Anyone know of any other places this stuff is available? Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted December 1, 2007 Author Share Posted December 1, 2007 Mekanik said: They did something goofy to the shrader valve too. Maybe it was leaking and they put that hose on the end to keep the fuel from leaking out. /forums/images/%%GRAEMLIN_URL%%/scratchhead.gifit doesn't leak at all, at some time I guess the schrader valve cap was lost so a plastic hole plug was just stuck over the end /forums/images/%%GRAEMLIN_URL%%/hammer2.gif At least it has a cap.. /forums/images/%%GRAEMLIN_URL%%/shrug.gifFWIW the truck does run good for it's "classic vintage" I was afraid that the missing hose may have been the cause of the leaks but it seem not to be the case so I didn't mess with the hose I'm just gun shy about old crap like that,it's working fine and has no issues don't fool with it!!! Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 1, 2007 Share Posted December 1, 2007 ktmlew said: Found this site for a parts kits for these. http://www.mwfi.com/dieselPage/ford_73.htm Anyone know of any other places this stuff is available? Yep me I've got all this stuff and more, all you have to do is call... I helped Keith out with the delivery valve that is not a available service part. We are a full blown Stanadyne,Bosch,etc...factory service center most of the Turbo and Diesel shops you deal with order the injectors, pumps and etc from us. The kit you are refering to is pretty simple it is available in either the 6.9 of 7.3 and comes with the hose,clamps,plastic tees,injector orings and copper seals. Sells over the counter for about $28.00 plus the gov. share. Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted December 2, 2007 Author Share Posted December 2, 2007 LARRYATSTI said: Yep me I've got all this stuff and more, all you have to do is call... Hey Larry maybe you could put the number in your Signature. /forums/images/%%GRAEMLIN_URL%%/shrug.gif the web sight for your shop doesn't have much info on what you guys carry. Superior Turbo and Injection 3735 Central Ave. Detroit, MI 48210 Phone: (313) 842-4616 Toll Free: 800-525-0164 Fax: (313) 842-2566 Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 2, 2007 Share Posted December 2, 2007 6.9 # 69120 7.3 # 73120 Both the same price. I have been working with my employer to get the web site more interactive, it looks like we will have it up and running before to long. As for now you can call or email or p/m me and I will get back with you asap. Quote Link to comment Share on other sites More sharing options...
