NO START DUE TO HIGH PRESSURE OIL LEAK
JUST TO GIVE SOME FYI ON THIS ENGINE IF YOU GET A 4.5 DEISEL AND YOU FIND LOW ICP PRESSURE THE HP OIL PUMP HAS THE SAME FITTING AND BLOCK AS THE 2005-2007 6.0 BUT THIS ONE EASIER TO REPLACE THEN THE 6.0 EASIER TO GET TO EVERYTHING
  • 5 months later...
  • 1 month later...
Hey International Tech, do you work at CIT in Columbia? I work at the Greenville location.
Yeah, they use the same bracket kit for the fitting as well. That is all that I have done for the past couple of months. As soon as I get done with one, another rolls in the shop, wether it be in a 275 or 365. Even did one in a Ford.
