DocRufo Posted April 22, 2014 Share Posted April 22, 2014 Good Morning, I've got a real toughy here. 2012 Focus 2.0 GDI intermittent No Crank/No Start. The starter relay will not click and the solenoid will not click. Battery ok, all TSB's and SSM's checked. Only fault code is in the BCM B10E5:15 PCM Wakeup signal open or short to battery. Any common issues anyone has ran into? The wiring diagram for this PCM Wakeup signal is very vague and the PCM connector is such a PITA to get to that by the time I've got access to the PCM connector the engine will start fine again. I wasn't even sure if this circuit was the issue or not so I depinned it from the BJB and the concern still occurs intermittently like I did nothing. I no longer have access to running a hotline request or the FMCdealer forums as I'm a Ford technical instructor now. Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
DocRufo Posted April 22, 2014 Author Share Posted April 22, 2014 Also worthy to note this PCM wakeup signal is not present on later model foci. 2013 and 2014 the circuit is gone from the diagram. Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted April 23, 2014 Share Posted April 23, 2014 If you overlay that wire from the PCM to the bcm will the concern continue? Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 24, 2014 Share Posted April 24, 2014 I have had bad grounds under the airfilter box. Just like when the focus first came out. Quote Link to comment Share on other sites More sharing options...
DocRufo Posted April 25, 2014 Author Share Posted April 25, 2014 Chris - I honestly haven't tried overlaying the wire. It's a real pain to get to the PCM on this car and Id have to run the wire through the firewall. I would try overlaying but I don't think the wire has intermittent fault - I depinned the wire and ran the car for a week without having the circuit in place. The code still came back as a CMDTC and it still was behaving the exact same way - intermittent no crank/delayed crank. I believe I've tested the circuit completely enough where I know it's not a circuit fault. I may try overlaying it anyway this weekend. Tony - I checked the grounds previously due to an SSM or TSB recommending that. Also recommended checking a battery cable connection in the high current fuse box which was also ok. I spoke to a local ford dealer parts department. The BCM has had its part number superseded something like 6 times and he's sold 8 BCMs in the last 6 months. I know that doesn't mean much but it does make me more confident it is probably the BCM. Thanks for the help. A friend of mine is contacting and an FSE to see I can get some more info on this circuit. Like what PIDs I should be reading. Quote Link to comment Share on other sites More sharing options...
