mchan68 Posted December 29, 2009 Share Posted December 29, 2009 Okay, I have one here that I just did an 07S57 on, a week ago that came in on the hook as a no-start. ALL sensor readings (BARO, EBP, MAP, ICP volts, ICP psi, IPR duty cycle, RPM and V-PWR) are bang on. Fuel pump IS being commanded at every key-on cycle. I have a hard P1277 and P1293 DTCs. After playing musical IDMs with two other customer's trucks without success, where else does that leave me? Am I going "under cover" as in under bank #1 valve cover, assuming wiring from IDM to bank #1 valve cover electrical connector checks out good? I knew I shouldn't have gone into work today on my birthday Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted December 29, 2009 Share Posted December 29, 2009 Happy Birthday! How does the buzz test sound- loud and clear on all 8? Have you taken a fuel sample into a clear jar from the yellow lever and inspected it for odor, water, and debris? What's the GP amperage measured at the fat lead on the GP relay? You're measuring RPM with the scan tool and not the dash, right? Have you checked fuel pressure at (at least) one head? I'd be less concerned about the P1277 and P1293 causing the no start and look at the bigger picture instead of concentrating on one cylinder. If you want to do a quickie test, pull the VC connectors off (without pulling the VC) and ohm each of the injector circuits. I use 2.77-3.17Ω as my go/nogo window. I'm in the office today, 440-846-3885 if you want.... Good Luck! Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 29, 2009 Author Share Posted December 29, 2009 Bank #1 UVC harness it is for the WIN!!!. I must be getting old. I vaguely remember a TSB for some "Jesus Clips" that is supposed to prevent a re-occurence of this very issue. Having some trouble locating it, if someone can help me with it. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 29, 2009 Share Posted December 29, 2009 See this article: 7.3L UVC Harness Retainer Clips Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 29, 2009 Author Share Posted December 29, 2009 Thanks Keith and Bruce. You guys rock!!! Quote Link to comment Share on other sites More sharing options...
G. Bedford Posted December 29, 2009 Share Posted December 29, 2009 Before just adding the clips, take a look at the spread of the female terminals in the UVC harness. As the clip separates and hangs, along with the heat and vibration, the terminals can really widen and cause a poor tension fit to the male spade of the valve cover gasket. One of our techs added clips only and then had an open circuit when the male spade was dead centered into the female terminal. On high mileage rigs I bid new UVC harnesses to avoid a concern later. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 29, 2009 Author Share Posted December 29, 2009 G. Bedford said: Before just adding the clips, take a look at the spread of the female terminals in the UVC harness. As the clip separates and hangs, along with the heat and vibration, the terminals can really widen and cause a poor tension fit to the male spade of the valve cover gasket. One of our techs added clips only and then had an open circuit when the male spade was dead centered into the female terminal. On high mileage rigs I bid new UVC harnesses to avoid a concern later.This truck is getting the clips, UVC harnesses and cover gaskets due to its high mileage to avoid having any future concerns. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 30, 2009 Share Posted December 30, 2009 Damn Mike! Why not epoxy the connections too... just to be safe! Quote Link to comment Share on other sites More sharing options...
Aaron Posted December 30, 2009 Share Posted December 30, 2009 ^^^^ Quote Link to comment Share on other sites More sharing options...
G. Bedford Posted December 30, 2009 Share Posted December 30, 2009 No need for clips with the latest design UVC harness. There are now bumps on the underside of the lock tabs to make a positive latching. Compare the old to new UVC harness and you will see what I'm talking about. If you attempt to force a clip in there it will break the tab on your new harness. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 30, 2009 Author Share Posted December 30, 2009 G. Bedford said: No need for clips with the latest design UVC harness. There are now bumps on the underside of the lock tabs to make a positive latching. Compare the old to new UVC harness and you will see what I'm talking about. If you attempt to force a clip in there it will break the tab on your new harness.Yes, I figured this out AFTER. Thanks anyhow. Quote Link to comment Share on other sites More sharing options...
