1991 idi 7.3 fuel problem return lines
Have a 1991 f-250 with a idi non turbo 7.3 liter that keeps blowing the fuel return lines off. I have tried blowing air through the return line to tank and it is free and not clogged up. I have replaced the caps and lines still doing it usually when under load is when it happens or high rpm. Replaced clamps with worm gear style then it split a line  so it seems to be getting excessive pressure in the return system. Any ideas or areas u guys have seen cause this? thanks for any replys
