6L injector nipple OIL RAIL o-ring kit and tool
I'm mad, last week I was on ebay searching through miscellaneos 6.0L stuff and came accross someone who sells o-ring kits with the hex socket needed to remove the nipples from the oil rail. He also had o-ring kits available if you had already bough the kit with the tool. Now this week I go back and I cant find the stuff anywhere. Does anyone know where I can get the o-rings and tool? Or at least the o-rings since I'm sure I could make the tool myself if I had to. I'm so irritated that I cant find it again. Havent seen it offered anywhere else and it could really be a great thing to have. Replacing the entire oil rail is bs when all it needs is o-rings.
when I seen it last week on ebay it was listed in a store, not an idividual so I'm not sure why I cant find it now, but when I do I'm going to share it with everyone I can. The listing had a kit of 8 o-rings and the tool for $49, and just the o-ring kit for $19, considering the stuff is top secret everywhere else I thought that was a great price. but I found it so easily that I didnt think I needed to save it or bookmark it. Apparently that was a big mistake.
Victor Reinz GS33445 is the only thing I can find as a possible service part for these seals. They are referred to as a "Pressure Upper Injector Oil Inlet Seal"
Still looking for info regarding a socket to remove these tubes
they also list this as a replacement for W301373, this is an upper injector seal for a 7.3 injector. I wonder if it's the same o-ring?
thanks I'll pass it on and I'm gonna get that fitting and check it out, I just happen to have one with valve covers coming off monday so maybe I'll have to pull a rail and if so I'll try this. Its an 03 and the only ones I've seen with bad rail orings were on 03 models
  • 3 weeks later...
So what about getting the nipple separate? I have a rail with dicked up nipples that keep blowing out the o-rings on the injector. The rail is on backorder for 2.5months which is total bs to expect to wait that long for a part! Its a fleet vehicle and I can not have it out of service for that long
  • 7 months later...
Yes, and they are only available from the aftermarket, Alliant Power PN AP 0002 IIRC. It includes a complete external seal kit for the injector and the snap ring on top. I've changed the D-ring without removing the snap ring.
That's my project for today. I had one of those O-rings fail on an aftermarket injector and I'm being sent O-rings for all of the injectors and a tool to remove the snap ring.
I tried for a few minutes and then ended up just replacing the D-rings without removing the snap rings. I was able to sneak it in there.
Coincidentally I was on the phone this morning with the guy who rebuilds injectors and asked him. He said that he's never actually removed one of those snap rings. Posted Image
I have struggled considerably to get the snap ring out. It's easier to change the D-ring with the snap ring in place.....
Well if YOU do it with the snap ring in place, then I don't feel so bad! Posted Image
