06 F350 Cab & Chassis
ETS
I have found a 06 F350 in TX. only has 7880 miles accroding to speedo. Looks as new, 6.0, auto, 4x4, 141wb, upfitters, cloth, trailer tow, cd, etc. Great work truck with flat bed, or maybe a little dump.
Wonder if someone would be kind enough to run oasis history on it for me. VIN 1FDWF37P46EC92174.
He is telling me 1 owner, Little old man who never used it on a ranch..... yada yada.
Wondering if it is a wreck or lemmon. Car fox is clear.
Thanks In Advance, Mike
Quote:
OASIS RESULT: 1FDWF37P46EC92174 USA: EN-US 08-SEPTEMBER-2012 / 21:40:21 EST/ APP2
Local Time: 8-SEPTEMBER-2012 / 9:40:20 PM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2006 F-SERIES BODY STYLE: F-350 CHASSIS CAB REGCAB 4X4 ENGINE: 6.0L DIESEL DI V8
TRANSMISSION: TORQSHIFT AXLE CODE: 4N ENGINE CALIBRATION
PAINT COLOR: OXFORD WHITE WB C/C-W/B PAINT CODE: Z1 RADIO: ELETR PREM AM/FM STRO/DISC
AXLE RATIO: 4.10 FINAL DRIVE RATIO WHEEL SIZE: 6.5 X 17 STEEL WHEEL FRONT TIRE: LT245/75/R17E A/T BSW
GROSS VEHICLE WEIGHT: 13,000 LB. GVW
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
ACCURATE REPAIR NOTIFICATIONS
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 21-OCTOBER-2006 BUILD DATE: 18-FEBRUARY-2006 SALE MILEAGE: 00510
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Click Here for Full Warranty History
| Report a Vehicle Concern | On-line 1878
END OF OASIS REPORT FOR 1FDWF37P46EC92174
Quote:
Detailed Vehicle Specification
Vehicle Line T/F7 Market Derived Code F
Body Cab T/BB Ver. Series T/CD
Drive Type T/E
PLT CD A1 TRS CD T/BE ENG CD T/YB
Production Date 18-FEB-06 Warranty Start Date 21-OCT-06
Selling Dealer 152419 Selling Country USA
AWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 2784098 2 4 2.4 ELLIOTT FORD LINCOLN 598 29-JAN-07 6C3Z 9B249 A 06399901
Customer Comments WATER IN FUEL LIGHT IS STAYING ON
Tech Comments 1 DIESEL ENG PERF DIAG P2269 RUN PINPOINT TESTS REPLACE WIF SENSOR SHORTED REPROGRAM MODULES ROAD TEST RETEST
Details 8604000 S07 35 .6 QUITMAN FORD, INC. 3788 31-AUG-09 * RECALEM * 08271201
Customer Comments CK ENGINE LIGHT ON
Tech Comments REPROGRAM FICM PER TSB 09 07 11
Details 8600631 S07 35 1.7 QUITMAN FORD, INC. 3788 31-AUG-09 6C3Z 6C640 B 08271202
Customer Comments CK FOR TURBO HOSE BLOWN,HOLE IN IT
Tech Comments FOUND TURBO HOSE BLOWN OFF,REPLACED HOSE,PERFORM ENGINE PERFORMANCE DIAG,TEST BOOST PRESSURE FOR OVER BOOST,PERFORM TURBO TEST,TEST PASS
Details 8789125 S07 38 4.8 QUITMAN FORD, INC. 3957 19-NOV-09 5C3Z 6K682 CARM 08357501
Customer Comments CK ENGINE FOR NO POWER INTER
Tech Comments PERFORM ENGINE PERFORMANCE TEST,FOUND LACK OF POWER,PERFORM TEST DRIVE & MONITOR PID DATA,FOUND LACK OF BOOST PRESSURE,TEST FOR STICKING TURBO,NEC C TO REMOVE TURBO,FOUND VEINS DAMAGED & CANNOT BE CLEANED,REPLACE TURBO & VERIFY REPAIR,MT FOR DISASSEMBLY AND ASSEMBLY OF TURBO
Quote:
Document Number 06399901
Repair Date 29-JAN-2007
Distance 598
Time In Service 4
Vehicle Information
Model Year 2006
Market Derived Code F - FORD
Body/Cab Type T/BB-SINGLE CAB (REGULAR CAB)
Version/Series T/CD-350 SERIES
Drive Type T/E-4 WHL L/H PART TIME DRIVE
Vehicle Line T/F7-F-SERIES OVER 8500 GVW [99-10]
Warranty Start Date 21-OCT-2006
Production Date 18-FEB-2006
Dealer Information
Dealer Name ELLIOTT FORD LINCOLN
Dealer Code 01637-*
Address 2055 W BURTON RD
City MOUNT PLEASANT
State TX
Zip Code 75455
Country USA
RegionCode NA
Phone
Expense Information
Customer Paid Amount $0.00
Deductible Amount $0.00
Dealer Paid Amount $0.00
Labor Cost $157.11
Misc. Expense Amount $0.00
Material Cost $60.16
Total Cost Gross $217.27
Comments
Customer Concern Code G29-OTHER WARNING LIGHT/GAUGE TROUBLES (VOLT/AMP)
Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment 1 DIESEL ENG PERF DIAG P2269 RUN PINPOINT TESTS REPLACE WIF SENSOR SHORTED REPROGRAM MODULES ROAD TEST RETEST
Customer Comment WATER IN FUEL LIGHT IS STAYING ON
Labor Details
Labor Op Code Labor Op Description Cost
6005F ENGINE PERFORMANCE DIAGNOSTICS - 7.3L DI TURBO EN DIAGNOSIS $26.18
6005F1 KEY ON ENGINE OFF - KOEO CHECK TEST $6.55
6005F1X1 EXTRA TIME TO REPEAT FINAL QUICK TEST $6.55
6005F6 KEY ON ENGINE RUNNING - KOER CHECK TEST $6.55
6005F13 $13.09
6005F45 $19.64
9249A HEADER - FUEL FILTER REPLACE $45.82
MT12650 $32.73
Parts Details
Casual Flag Prefix Base Suffix Part Description CPSC Part
Quantity Extended
Amount
Y 6C3Z 9B249 A HEADER-FUEL FILTER 100106 1 $60.16
Print
Close..
Quote:
Document Number 08271201
Repair Date 31-AUG-2009
Distance 3788
Time In Service 35
Vehicle Information
Model Year 2006
Dealer Information
Dealer Name QUITMAN FORD, INC.
Dealer Code 01491-*
Address 539 EAST GOODE
City QUITMAN
State TX
Zip Code 75783
Country USA
RegionCode NA
Phone
Expense Information
Labor Cost $39.66
Material Cost $0.00
Total Cost Gross $39.66
Comments
Customer Concern Code E29-CHECK ENGINE LIGHT TROUBLE
Condition Code 04-SOFTWARE REVISION, FLASH MODULE
Technician Comment REPROGRAM FICM PER TSB 09 07 11
Customer Comment CK ENGINE LIGHT ON
Labor Details
090711A $39.66
Parts Details
Quantity Extended
Amount
Y * RECALEM * ECC PROCESSOR RECAL - EMISSIONS 031405 0 $0.00
Print
Close.
Quote:
Document Number 08271202
Distance 3788
Time In Service 35
Vehicle Information
Model Year 2006
Dealer Information
Dealer Code 01491-*
City QUITMAN
State TX
Zip Code 75783
Country USA
RegionCode NA
Phone
Expense Information
Labor Cost $112.37
Misc. Expense Amount $85.00
Material Cost $50.34
Total Cost Gross $247.71
Comments
Customer Concern Code D50-OTHER ENGINE TROUBLES
Technician Comment FOUND TURBO HOSE BLOWN OFF,REPLACED HOSE,PERFORM ENGINE PERFORMANCE DIAG,TEST BOOST PRESSURE FOR OVER BOOST,PERFORM TURBO TEST,TEST PASS
Customer Comment CK FOR TURBO HOSE BLOWN,HOLE IN IT
Labor Details
6005F ENGINE PERFORMANCE DIAGNOSTICS - 7.3L DI TURBO EN DIAGNOSIS $26.44
6005F1 KEY ON ENGINE OFF - KOEO CHECK TEST $6.61
6005F38 $39.66
6005F45 $19.83
6646AH $19.83
Parts Details
Quantity Extended
Amount
Y 6C3Z 6C640 B CONNECTION A/C DUCT 031202 1 $50.34
Quote:
Document Number 08357501
Repair Date 19-NOV-2009
Distance 3957
Time In Service 38
Vehicle Information
Model Year 2006
Dealer Information
Dealer Code 01491-*
City QUITMAN
State TX
Zip Code 75783
Country USA
RegionCode NA
Phone
Expense Information
Labor Cost $317.28
Material Cost $1,231.09
Total Cost Gross $1,548.37
Comments
Customer Concern Code D42-POOR PERFORMANCE/LACKS POWER
Technician Comment PERFORM ENGINE PERFORMANCE TEST,FOUND LACK OF POWER,PERFORM TEST DRIVE & MONITOR PID DATA,FOUND LACK OF BOOST PRESSURE,TEST FOR STICKING TURBO,NEC C TO REMOVE TURBO,FOUND VEINS DAMAGED & CANNOT BE CLEANED,REPLACE TURBO & VERIFY REPAIR,MT FOR DISASSEMBLY AND ASSEMBLY OF TURBO
Customer Comment CK ENGINE FOR NO POWER INTER
Labor Details
6005F1X1 EXTRA TIME TO REPEAT FINAL QUICK TEST $6.61
6005F2 KEY ON ENGINE OFF - KOEO INJECTOR ELECTRICAL SELF TEST $6.61
6005F6 KEY ON ENGINE RUNNING - KOER CHECK TEST $6.61
6005F8 LOW IDLE STABILITY (ICP PRESSURE) TEST $39.66
6005F10 CYLINDER CONTRIBUTION TEST $6.61
6005F13 $13.22
6005F14 $6.61
6005F18A $13.22
6005F39 $19.83
9438A TURBOCHARGER ASSEMBLY REPLACE $132.20
MT091605 $33.05
Parts Details
Quantity Extended
Amount
N 6C3Z 6C640 A CONNECTION A/C DUCT 031202 1 $53.19
Y 5C3Z 6K682 CARM TURBO CHG-EXH DRIVE 030407 1 $1,173.90
N * W302725 * 030407 1 $4.00
Print
Close..
Quote:
GENERAL VEHICLE INFORMATION: (Related Claims)
VIN: 1FDWF37P46EC92174 Veh Line: T/F7 - F-SERIES OVER 8500 GVW [99-10] Eng Serial No: 402066748104
Model Year: 2006 Market Derived: F - FORD Body Shell: *
Veh Type: T Drive Code: T/E - 4 WHL L/H PART TIME DRIVE Engine: T/YB - 6.0L 325H/550# OHV DI TC V8 DS
Inv. Dealer: * Body Cab Style: T/BB -SINGLE CAB (REGULAR CAB) Transmission: T/BE - 5 SPD AUTO 5R110W - HI/TORQUE
Version/Series: T/CD - 350 SERIES
Trace Eng Serial No:
---------1----------2---------3--------4---------5-----------6----------7---------8
EN200 1402066748104
Trace Trans Serial No:
A4532 130206A1U60521206C3P-7000-KB
BUILD INFORMATION:
Region: NA - ########## Plant: A1 - KENTUCKY TRUCK PLANT BUILD
Country: USA - ########## Prod Date: 18-FEB-2006
SALE INFORMATION:
Region: NA - ########## Selling Dealer: 152419 -*
Country: USA - ########## Selling Dlr St/Prov: TX
Buyer St/Prov: *
Arrival Date: 01-MAR-2006 Red Carpet Lease: *
Sale Date: 21-OCT-2006 Fleet/Retail/Co. Lease: F
Warranty Start Date: 21-OCT-2006 Modified Vehicle: *
Orig Warranty Date: 21-OCT-2006 Reacquired Vehicle: * Vehicle Export Flag: N
VOC/EOC:
---------1---------2---------3---------4---------5---------6---------7---------8----------9----------
F376EC92174141Z6 3M5B23A6185 LA E 5 B4NZBM259 D2 252 J 3ZS C52W517 404 Z1 CHGT DP
1FDW4 3 P 640A 9PBOK
INSTALLED OPTION INFORMATION:
Air Conditioning: T/B - MANUAL AIR CONDITIONER GVW Code:
Alternator Amp Rating: 6D GVW Class Code: W
Audio Disk: * - [N/A] Instrumentation: * - [N/A]
Axle Ratio: EGAMD - 4.10 FINAL DRIVE RATIO Mirror(Driver Side): BD - DRIVER LARGE HEAD/LONG ARM MIR
Axle Type: EGJAC - LIMITED SLIP REAR AXLE Mirror(Psngr Side): * - [N/A]
Battery Amp Rating: 5B Paint: PNYW5 - OXFORD WHITE WB C/C-W/B
Brake Code: FBAAJ -POWR 4-WHEEL DISC HYDRO BOOST Power Antenna: * - [N/A]
Brake Code(Service): * -[N/A] Radio: AU - ELETR PREM AM/FM STRO/DISC
Calibration Code: * Sound System: * -[N/A]
Color(Accent): * - [N/A] Suspn Tandem Axle:
Color(Trim): 000BY - MEDIUM PEBBLE Tire Brand: AE - B.F. GOODRICH
Delivery Type: 3 Tire Size: D3KBM - LT245/75/R17E A/T BSW
Driveshaft Code: * Traction Control: * - [N/A]
Front Seat: T/E - SEAT-FULL BENCH Wheel Base:
Fuel Type: AJ -DIESEL FUEL CAPABILITY
TIRE DOT INFORMATION:
LF: M343DP110606 RF: M343DP110606
LR: M343DP110606 RR: M343DP110606
LI: M343DP110606 RI: M343DP110606
SPARE: M343DP110306
ESP INFORMATION: EMISSIONS INFORMATION:
ESP Code: * Emission Code: DGAAE - DGAAE
ESP Coverage(Miles): * Emission Cert Type: 5
ESP Coverage(Time): * Emission Decal Suffix: NJL
ESP Plan Year: * Engine Family: 6FMXA060AED
ESP Signature Date:
Thank You Mr. Clayton,
It says near bottom; Fleet Vehicle, Modified. Does this refer to beaing Cab & Chassis? Or was it sent to aftermarket for refitting and returned? No clues of what kind of bed was on it. Or added holes in dash for controls.
Will engine idle hours show up on scanner in 06? .
Looks like it may be a good one.
Thanks Again, Mike
I was asking how many times and proper sequence to get engine hours to show up on cluster. I am unable to find it in owners manual or shop manual.
Interesting hours to miles is so low. As we all know 60 mph is a mile a minute. And idling is harder on these engines than running them at speed.
Eh, you gotta fiddle fuck with the odometer reset button to get it to scroll to the hour meter. I can't remember but I think you get it to the system check portion and then cycle through. It's easy to do when I have one in front of me, but sitting here at home on the computer is a different story! Posted Image
an 06 should just need to keep pushing the reset button until you get to eng hrs, it's the 08's that you go to system check and then hold reset and let it cycle through the system check.
